  2. Functional Verification
  3. code coverage block analysis
  • Subscribers 69
  • Views 13131
Mahesht6
Mahesht6 over 4 years ago
Hi team,
I am analysing code (block) coverage, I need help with the following;
LINE1: always @(cmd_enable)
LINE2: begin
LINE3: action1: assign
LINE4: action2: display
LINE5: end
in imc coverage report, I was able to see that LINE2 0% covered. How LINE2 will be covered.
If LINE1 is not covered, means, then its is fine, the entire block will not get covered.
But it was pointing out only at LINE2.
Please suggest
  • samiirlore
    samiirlore over 4 years ago
    My take on code coverage is that it's only really good if I can see which lines are covered in my editor/IDE. I don't fool myself into thinking that lines that are covered are perfect. But if I can tell by looking at the source what lines aren't covered, I'm much more aware of if there are critical paths that aren't
      kodi nox
