  2. Functional Verification
  3. xrun cannot initialize values
  • Subscribers 68
  • Views 15986
quantumion
quantumion over 4 years ago
Context: a digital design, with memory elements
Goal: run power simulations with Voltus
Conditions: need to run the behavioral simulations using systemverilog testbenches where it is really important to initialize the values of all elements, aiming to avoid undefined values in the signals, in the post-simulation exported VCD waveforms. For that I used the xcelium simulator's command -xminitialize
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009MoQDUA0&pageName=ArticleContent
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000vhucEAA&pageName=ArticleContent
the list of nets, registers, flipflops and memories initialized and the value exactly is done with the option below, and it worked
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009EWnaUAG&pageName=ArticleContent
However the nets are not initialized, check the screenshot Post
/resized-image/__size/1280x960/__key/communityserver-discussions-components-files/30/gtkwave.png
p.s. the full simulation is invoked by a command of this structure
xrun -stats -ieee1364 -errtcl_verbose -access r -timescale 1ps/1ps -top tb_full -v200x -64bit -ALLOWREDEFINITION -gui VHDL/file1.vhd VHDL/file2.vhd Verilog/file1.sv Verilog/file2.v -linedebug -sv -xminitialize rand:4 -xminit_log init_list.log  tb_file1.sv
thank you on any advice on how to run this correctly
  • StephenH
    StephenH over 4 years ago +1
    My understanding is that xminitialize works for variables (reg and memory) only and does not work for wires (nets). That's why the 2nd link you referred to talks about using Tcl to deposit values onto…
  • StephenH
    My understanding is that xminitialize works for variables (reg and memory) only and does not work for wires (nets). That's why the 2nd link you referred to talks about using Tcl to deposit values onto nets. In principle I would expect nets to get new values based on the initialised regs once the design starts and the always blocks evaluate their outputs.
