  2. Functional Verification
  3. Regression with Vmanager
  • Subscribers 68
  • Views 15860
Senemilk
Senemilk over 4 years ago
I am new to using Vmanager and I have multiple vsif files for lunching the regression of multiple blocs.
But I would like to have an automatic regression launched every week for example with a combination of all the previous regressions I launched.
Is there any way to do that ?
Through a script maybe or a vsif file which would combine all the previous ones ? It would be great if I could have some examples too.
Thanks in advance.
  • StephenH
    StephenH over 4 years ago
    We typically do this using #ifdef and #include in the VSIF, for example you can have your block-level VSIF looking something like this:
    // block1.vsif
    #ifndef TOPLEVEL
    session block1 {
      top_dir : ....;
    #endif
    group all {
      test test1 { ... };
      test test2 { ... };
    Then for the top-level VSIF:
    // top.vsif
    #define TOPLEVEL
    session top {
      top_dir : ....;
    #include "block1.vsif"
    #include "block2.vsif"
    This way you can directly re-use VSIFs without having to replicate test information.
  • Senemilk
    Senemilk over 4 years ago in reply to StephenH
    Thank you for your reply
    If I could just have some more details
    And I don't want to run a top level testbench that includes all those blocks but rather I want to run all those blocks separately (they could for example not be inside the same top level and we would have the same number of testbench environment as the number of blocs)
    If it is not possible to do that with one vsif file, I don't mind running them in succession but is there à way to do that from the terminal with a script for example ?
