  2. Functional Verification
  3. Indago waveform is not showing after Design reload
  • Subscribers 66
  • Views 10320
Abhishek Jaiswal
Abhishek Jaiswal over 3 years ago
I am facing the issue where indago waveform goes blank after I reload design. Below are the steps
1. I simulate and open the waveform in indago
2. find the RTL issue, fix it and re-run
3. reload the design after test is done.
After step 3, 70% time it is okay but 30% time it does not reload correctly and all the waveform window is blank. (though signal name is still visible)
If I close indago, (remove myDb and rerun the test it works fine.
What could be the issue?
Abhishek
