  2. Functional Verification
  3. Different result with vmanager and standalone simulation...
  • Replies 7
  • Subscribers 70
  • Views 16563
Different result with vmanager and standalone simulation, with same seed
djdjuric
djdjuric over 4 years ago
I am running standalone simulations with xcelium, and I have siimulation passing. When I run it in regression, simulation fails due to errors in the checkers, that I have implemented. Checkers are simple, only checking voltage levels at point of time, or calculating slew.
When I use the same seed from regression and run it standalone, simulation passes. Results in SimVision, when, observed look ok.
Types of errors are for example too much difference between expected and measured voltages.
I did check vsif file several times, and I don't see any difference between vsif and standalone setup. Only difference is seed, but as I said, even with same seed, I get pass in standalone.
Sorry, if my terminology is off, hope you will understand the issue.
Did anyone, have this kind of issue, adn can you point me what to check, or where to look? Thank you.
Best regards,
Djordje
  • StephenH
    StephenH over 4 years ago in reply to djdjuric +1
    What I was trying to say is that if you compare the logs for the same test+seed combination for vManager and stand-alone tests, you should be able to home in on the reason for the difference in result…
  • StephenH
    There are lots of possible ways your results might end up being different. Are you using SV randomize() in your testbench? If so, you could try adding "-xceligen heartbeat" to the xrun command in both setups and diff the logs to see if the seed sequence changes somewhere during the test. There are other solver options that can help, if heartbeat makes it look like a seeding issue, have a look at this article: How to debug Random Instability across the different runs of same test
    If you have waveforms for both tests, you could use the "simcompare" tool to diff the waveforms to identify the earliest point in time where the waves differ - it's easiest to do this inside SimVision using the "SimCompare Manager" under the "Tools" menu.
  • djdjuric
    djdjuric over 4 years ago in reply to StephenH
    Hi Stephen,
    first of all, I want to thank you for fast response.
    I am not sure if I am using randomize.I know that things that I drive from the test and testbench should be fixed. I know that I get different seed each time I run regression. But when I find that seed of a log in vmanager, and use it in standalone sim, I get that stand alone sim to pass, and it is failing in vmanager.
    Maybe I need to mention that other tests are passing for me in regression, and they are passing each time I run them. This issue is only on couple of tests. This is verification using Specman. I am new to this, so I might miss some terminology.
  • StephenH
    What I was trying to say is that if you compare the logs for the same test+seed combination for vManager and stand-alone tests, you should be able to home in on the reason for the difference in result.
    If you're using Specman instead of UVM-SV then you need to check the random stability / seed sequence a different way, but starting with a simple log diff would be best.
    You should even take care to check that the exact same set of "e" files are loaded, etc.
  • djdjuric
    Ok, I will do so and get back to you, thank you.
  • angelacoffey
    angelacoffey over 4 years ago
    I am aware that the items I pull from the test and testbench need to be corrected. Every time I perform a regression, I am aware that the seed is different. However, when I locate that log seed in vmanager and use it in a standalone sim, I am able to pass the stand alone sim while it is failing in vmanager words from letters
  • djdjuric
    Hi All,
    first I want to say thank you to StephenH. I found the issue with observing the log and looking into actual waveform of the sim. My problem was:
    1. I was using generate statement in Instance generation, for different setups.
    2. Generate function is elaborated and done only once in the begging. And it will take values from the initial, default setup in the model, as verification was using precompile script to speed up regressions, and everything after that was disregarded, in terms of generate setup.
    Luckily, I managed to see the issue, after a lot of careful observation of waves and logs.
    Conclusion: Generate function + precompile script was the issue.
    Thank you StephenH, I really appreciate the time and advice.
  • StephenH
    Great, I'm glad you found the source of the problem and were able to fix it! Thanks for the feedback. :)
