  2. Functional Verification
  3. Why does simvision sometimes causes the desktop freezed...
  • Subscribers 69
  • Views 14646
Why does simvision sometimes causes the desktop freezed?
aICer
aICer over 4 years ago
Below are some details,
1. OS: CentOS 7.9
2. sivision version: XCELIUM/22.03.004
When the simvision causes the desktop freezed, I killed simvision process, then the desktop back to un-freezed.
Thanks.
  • HoWei
    HoWei over 3 years ago
    Same problem here !
    XCELIUM 22.09.002  on RHEL 7.8
    That is a pain !
    Switching to open source tools  (icarusVerilog/gtkWave) for the time being.
  • StephenH
    StephenH over 3 years ago in reply to HoWei
    Which window manager do you use? KDE? Gnome? I've heard of cases where the Gnome shell gets stuck at 100% CPU, and resetting the display or re-sizing it can help. Someone suggested Alt+F2 then press "r" to reset the server, but I haven't tried this myself as my sessions don't hang.
  • tpylant
    tpylant over 3 years ago in reply to StephenH
    To restart the simulation after editing a file, you can use the Simulation -> Restart menu item. This will leave SimVision windows up and recompile/re-elaborate underneath.
    To limit the simulation time, the easist way is to enter "run 100ns" in the Console window. You can also "run -abs 300ns" if you want to run to the time 300 instead of advancing by 300.
  • HoWei
    HoWei over 3 years ago in reply to tpylant
    Thanks, thats working.  Slowly becoming familiar with simvision.
    I ried to find a "xrun"  commandline option to specify the simulation time - but did not find any.
    Is there a cmd-line option to specify the simulation time ?
  • HoWei
    "run -abs ..." is not working (anymore).
    It is "run -absolute" in Xcelium 22.09.
    I am stil looking for a command, how to specify the simulaiton runtime from commandline, such as:
     # xrun -f optionsfile -xmsimargs run -absolute 100ns   (not working example)
    Any idea ?
