  2. Functional Verification
  3. How do I add signal probes to Simvision waveform viewer...
  • Replies 19
  • Subscribers 69
  • Views 35013
How do I add signal probes to Simvision waveform viewer?
ianmurph
ianmurph over 4 years ago
I have some packages that live outside the top level testbench that drive some interfaces. I am trying to figure out how to add these signals into the waveform window. In Simvision, I can see all my packages and the signals from them, but they are in italics and say 'not probed':
How does one make these signals probed? Is there a file somewhere that tells the simulator what signals are probed? The simulation is run through a makefile script, here is a snippet from it. I tried adding the line that starts with 'probe' but I dont really know what I'm doing and this did not work:
if [ ! -d $(SIM_OUTPUT_DIR) ]; then mkdir $(SIM_OUTPUT_DIR); fi; \
cd $(SIM_OUTPUT_DIR); \
find . -type f -maxdepth 1 -delete; \
echo "Curent folder: "; pwd; \
irun -v200x -makelib rcf_lib ../../$(XSC_IP_DIR)/xsc_q7_neptec_ddvs_ntsc_ctrl_axi/src/hdl/constants_pkg.vhd -endlib \
-dumpstack -reflib xil_defaultlib $(IRUN_FILES) $(IRUN_SIM_OPT) $(IRUN_SIM_DEFINE_TC) $(IRUN_SIM_DEFINE_OPT) $(IRUN_CODE_COVERAGE_OPTIONS) -top $(TOP_LEVEL) -top glbl -logfile sim_log.log; \
probe -create -database waves::worklib.cpc_tools_pkg::cpc_tools -all -depth all
I may not have provided enough info to answer the quesiton, if so let me know what info is missing and I will try to answer it. Thanks in advance.
  • Doug Koslow
    Doug Koslow over 4 years ago
    Instead of hardcoding the top level name in your "probe" command, try replacing "waves::worklib.cpc_tools_pkg::cpc_tools" with "[scope -tops]".
    So your probe command becomes:
    probe -create -database [scope -tops] -all -depth all
    "scope -tops" will list out all the top levels of the design - including the packages. See if this addresses your issue.
    Thanks.
    - Doug
  • ianmurph
    ianmurph over 4 years ago in reply to Doug Koslow
    Thank you for the reply. Unfortunately this didn't resolve my issue, the signals inside my packages still say 'not probed'. For more information, my top level is set to my tb_fpga in the script:
    ifneq ($(TOP_LEVEL), 1)
    TOP_LEVEL = tb_fpga
    endif
    But my packages are outside of my tb_fpga.sv. In order to see my packages in the Design Browser at all, I have to right click and select 'Explore Full Design' (they are not there by default):
    Not sure if packages need to be included in the wave dump or somthing. Not sure if any of this info is relevant or not, this stuff is all pretty new to me. Thanks in advance!
  • Doug Koslow
    Doug Koslow over 4 years ago in reply to ianmurph
    At this point, I suggest filing a support ticket, and we can take the issue from there. (The command I gave should have probed the packages. We'll need to check why it did not.)
    Thanks.
    - Doug
  • ianmurph
    Okay, I am going to try opening a ticket. I am stilling trying to figure out what our licence server host ID is so that I can open the ticket. In the meantime, I did find more info on the issue. I am gettting an error message that says "... does not match any database name" Here is the full error message:
    ncsim> probe -create -database [scope -tops] -all -depth all
    ncsim: *E,DBNFND: @STD.STANDARD @SYNOPSYS.ATTRIBUTES @UNIMACRO.VCOMPONENTS @CDS_ASSERTIONS.cds_assertion_stubs @IEEE.std_logic_arith @IEEE.NUMERIC_STD @IEEE.NUMERIC_BIT @IEEE.std_logic_1164 @STD.standard_additions @STD.TEXTIO @UNISIM.VPKG @IEEE.VITAL_Primitives @IEEE.VITAL_Timing @RCF_LIB.constants_pkg @IEEE.std_logic_unsigned @AXI_DMA_V7_1_18.axi_dma_pkg @LIB_PKG_V1_0_2.lib_pkg @IEEE.std_logic_misc @XPM.VCOMPONENTS @AXI_SG_V4_1_10.axi_sg_pkg @AXI_EMC_V3_0_17.emc_pkg @IEEE.std_logic_signed @AXI_ETHERNETLITE_V3_0_15.mac_pkg @AXI_LITE_IPIF_V3_0_4.ipif_pkg @AXI_IIC_V2_0_20.iic_pkg @IEEE.MATH_REAL @WORKLIB.axi3s_gp_pkg @WORKLIB.vivado_pkg buffer_if glbl tb_fpga $unit_0x324b5966 axi4stream_vip_pkg:: $unit_0x1ef055ef axi_vip_pkg:: xil_common_vip_pkg:: testcase_colourbar_lwir_axi_pkg:: testcase_colourmap_lwir_axi_pkg:: $unit_0x06fbb5dc testcase_version_reg_pkg:: testcase_lwir_receiver_pkg:: lwir_video_model_pkg:: crc32_model_pkg:: lwir_receiver_pkg:: testcase_hdcs_axi_pkg:: cpc_tools_pkg:: common_pkg:: header_pkg:: does not match any database name.
    Any idea what this means?
  • Doug Koslow
    Please try these 2 commands:
    database -open -default waves.shm
    probe -create [scope -tops] -all -depth all
    Thanks.
    - Doug
  • ianmurph
    Hi Doug, thanks very much for the reply. This actually did changed some stuff, I can now see more packages in simvision  (just the axi_vip stuff) but it did not probe the package that I want to probe. Sorry I didn't mention this earlier, but I JUST realized some of the probing is happening in the testbench sv file rather than in the simulation scripts? I have these lines in the tb.sv:
    initial begin: waveform_dump
        $display("Waves dump is Enabled");
        $shm_open("waves.shm", 1);
        $shm_probe(tb_fpga, "ACMTF"); // add hierarchy here.
    end
    What does the ACMTF part do? Should I specify the packages I want to probe here? Adding the lines you provided to the tcl script did add some probes, but the log file now shows this error (among others):
    ncsim: *E,PRNONE: No new objects to probe in scope cpc_tools_pkg::.
  • Doug Koslow
    You're welcome.
    I would not recommend mixing the $shm-based probing and the Tcl "probe" commands. Can you try removing that initial block and leave the probe command and see if that helps?
    Thanks.
    - Doug
  • ianmurph
    I have commented out that entire inital block in my testbench and I am using the tcl commands you gave. I dont see much difference. When I open simvision, I can see the "Packages" drop down now, but there is only 3 packages there, not all of them:
    I am still getting the same error in the sim log:
  • Doug Koslow
    Did you provide read access to the package you want to probe during the compile?
    If you give the command:
    probe <package_name>::
    ...for the package you want to probe, do you get an error?
    - Doug
  • ianmurph
    Forgive me, not sure I fulyl understand how to check that. I added probe cpc_tools_pkg:: to the tcl and it gave this error:
    ncsim: *E,PBNODB: Cannot determine database for the given probe command.
    I also tried other variations all of which gave errors (*E,PBNODB, *E,PNOOBJ, and *E,PRNONE)
