  2. Functional Verification
  3. Hi i need help regarding one scenario i have two functions...
  • Subscribers 68
  • Views 8421
Hi i need help regarding one scenario i have two functions defined one basic tc and other sqc .... for now mu_value vaues based on the condition is getting calculated based on the given condition and are stored in mu.txt file..
Zainsidiquee17501
Zainsidiquee17501 over 4 years ago
Hi i need help regarding one scenario i have two functions defined one basic tc and other sqc .... for now mu_value vaues based on the condition is getting calculated based on the given condition and are stored in mu.txt file..But i need mu_value to be calculate for sqc condition also and be stored to mu.txt file .... So it should give me values like first basic case values which is stored currently and then some i should set up a condition to calculate mu_value for sqc and same to be stored in txt file followed by basic values ... But i am lacking the info how should i proceed with the below functions given ... I am dropping code below so if you understand anything about functions being used..
typedef enum {l,le,g,ge,eq} mu_cond;
typedef enum {And,Or,Nand,Nor} tc_cond;
typedef enum {AND,OR,NAND,NOR} sqc_cond;
module ila_seq_cap_input();
 string match_value,cc0,cc1,cc2,cc3,val;
 int tc_value,sqc_value;
 string tc,tc1,tc_1,sqc,sqc1;
 string op;
 string match_op,tc_op,sqc_op;
 int cc_value;
 int cap_bit_width,depth;
 int trigger_position_max,trigger_position_min;
 int window_size_max,window_size_min;
 int window_count_max,window_count_min;
 string value;
 string tc_val,tc_val1,sqc_val,mu_file,cc_file,tc_file,sqc_file,trigger_position_value;
 int mu_value[],mu_value1[$];
 int no_values,cc_sel;
 int trigger_position ,trigger_value[];
 tc_cond tccond;
 sqc_cond sqccond;
 mu_cond mucond=g;
 `ifdef p01023
  parameter C_PROBE0_WIDTH=1023;
 `elsif p0511
 parameter C_PROBE0_WIDTH = 511;
 `elsif p0512
 parameter C_PROBE0_WIDTH = 512;
 `elsif p0255
 parameter C_PROBE0_WIDTH = 255;
 `elsif p0127
 parameter C_PROBE0_WIDTH = 127;
 `elsif p064
 parameter C_PROBE0_WIDTH = 63;
 `elsif p08
 parameter C_PROBE0_WIDTH = 7;
 `elsif p05
 parameter C_PROBE0_WIDTH = 5;
 `elsif p016
 parameter C_PROBE0_WIDTH = 15;
 `elsif p031
 parameter C_PROBE0_WIDTH = 31;
 `else
 parameter C_PROBE0_WIDTH = 0;
 `endif
 `ifdef p11023
  parameter C_PROBE1_WIDTH=1023;
 `elsif p1511
 parameter C_PROBE1_WIDTH = 511;
 `elsif p1255
 parameter C_PROBE1_WIDTH = 255;
 `elsif p1256
 parameter C_PROBE1_WIDTH = 256;
 `elsif p1127
 parameter C_PROBE1_WIDTH = 127;
 `elsif p164
 parameter C_PROBE1_WIDTH = 63;
 `elsif p18
 parameter C_PROBE1_WIDTH = 7;
 `elsif p15
 parameter C_PROBE1_WIDTH = 5;
 `elsif p116
 parameter C_PROBE1_WIDTH = 15;
 `elsif p131
 parameter C_PROBE1_WIDTH = 31;
 `else
 parameter C_PROBE1_WIDTH = 0;
 `endif
 `ifdef p21023
  parameter C_PROBE2_WIDTH=1023;
 `elsif p2512
 parameter C_PROBE2_WIDTH = 511;
 `elsif p2255
 parameter C_PROBE2_WIDTH = 255;
 `elsif p2127
 parameter C_PROBE2_WIDTH = 127;
 `elsif p263
 parameter C_PROBE2_WIDTH = 63;
 `elsif p264
 parameter C_PROBE2_WIDTH = 64;
 `elsif p28
 parameter C_PROBE2_WIDTH = 7;
 `elsif p25
 parameter C_PROBE2_WIDTH = 5;
 `elsif p216
 parameter C_PROBE2_WIDTH = 15;
 `elsif p231
 parameter C_PROBE2_WIDTH = 31;
 `else
 parameter C_PROBE2_WIDTH = 0;
 `endif
 `ifdef p31023
  parameter C_PROBE3_WIDTH=1023;
 `elsif p3512
 parameter C_PROBE3_WIDTH = 511;
 `elsif p3255
 parameter C_PROBE3_WIDTH = 255;
 `elsif p3127
 parameter C_PROBE3_WIDTH = 127;
 `elsif p364
 parameter C_PROBE3_WIDTH = 63;
 `elsif p38
 parameter C_PROBE3_WIDTH = 7;
 `elsif p35
 parameter C_PROBE3_WIDTH = 5;
 `elsif p316
 parameter C_PROBE3_WIDTH = 15;
 `elsif p331
 parameter C_PROBE3_WIDTH = 31;
 `elsif p332
 parameter C_PROBE3_WIDTH = 32;
 `else
 parameter C_PROBE3_WIDTH = 0;
 `endif
  `ifdef 1023
  parameter C_PROBE_WIDTH=1023;
 `elsif 768
  parameter C_PROBE_WIDTH=768;
  `elsif 511
  parameter C_PROBE_WIDTH = 511;
  `elsif 255
  parameter C_PROBE_WIDTH = 255;
  `elsif 127
  parameter C_PROBE_WIDTH = 127;
  `elsif 64
  parameter C_PROBE_WIDTH = 63;
  `elsif 8
  parameter C_PROBE_WIDTH = 7;
  `elsif 5
  parameter C_PROBE_WIDTH = 5;
  `elsif 16
  parameter C_PROBE_WIDTH = 15;
  `else
  parameter C_PROBE_WIDTH = 31;
  `endif
 int fd;
 int trigger_count;
 int no_probes=1;
 int mu_count=1;
     function void parse(output int s [], output int size_s,input byte separator, input string in);
    int index[$];
    string out[];
    s.delete();
    foreach(in[i]) begin // find commas
        if (in[i]==separator) begin
               index.push_back(i-1); // before comma
            index.push_back(i+1); // after comma
        end
    end
    index.push_front(0); // first index
    index.push_back(in.len()-1); // last index
    out = new[index.size()/2];
    s=new[index.size()/2];
    foreach (out[i]) begin
          out[i] = in.substr(index[2*i],index[2*i+1]);
      $display(" out=%h", out[i].atoi());
      s[i]= out[i].atoi();
    end
    size_s=s.size();
    index.delete();
    out.delete();
  endfunction : parse
 function automatic get_string(int n, int width,ref string s);
  int a;
    s.bintoa(n);
    //$display("%s %d",s,s.len());
    a=s.len();
    for (int i=0;i<width-a;i++) begin
      s={"0",s};
    end
       //$display("%s",s);
    endfunction
 function automatic get_mu_string(int n, int width,ref string s);
  int a,b;
    s.bintoa(n);
   // $display(" %d %s %d",width,s,s.len());
    a=s.len();
    b=s.len();
    for (int i=0;i<(width-b);i++) begin
    if(a%4!=0) begin
    s={"0",s};
    a++;
    //$display("%s %d",s,a);
    end
    else begin
    if(match_op=="==")
      s={"x",s};
    else
      s={"0",s};
    //$display("%s %d",s,i);
    end
    end
      match_value = {match_op,s};
      op=match_op;
     $fdisplay(fd,"%0d",n);
     $fdisplay(fd,"%s",match_value);
     $fdisplay(fd,"%s",match_op);
       //$display("%s",s);
    endfunction
 function automatic get_x_string( int width,ref string s);
    s="";
    for (int i=0;i<width;i++) begin
      s={"x",s};
    end
  endfunction
  function void cap_width(input int s, output int a);
    while(s!=1)
    if(s%2==0) begin
      a++;
       s=s/2;
      end
  endfunction
  // import "DPI-C" function string get_string(int value,int width);
  function tc_config(input int tc_value,input string tc_op);
   if($value$plusargs("tc_file=%s",tc_file))
   fd=$fopen(tc_file,"a");
   tc.bintoa(tc_value);
    $display("before for loop %s %d",tc_op,tc_value);
   for(int i=0;i<(no_probes*mu_count);i++)
   tc1={tc1,tc};
   tc_val={tc_op,tc1};
   if(mu_count>1)
   for(int i=0;i<(no_probes*mu_count)-no_probes;i++)
   tc_1={tc_1,tc};
   else
   tc_1={tc_1,tc};
   tc_val1={tc_op,tc_1};
   $display("%s tc1 %d",tc_op,tc1);
   $display("%s tc_val  %s %s",tc_op,tc_val,tc_val1);
   $fdisplay(fd,"%s",tc_val);
   $fdisplay(fd,"%s",tc_val1);
   op=tc_op;
   $fdisplay(fd,"%s",tc_op);
   $fclose(fd);
 endfunction
  function sqc_config(input int sqc_value,input string sqc_op);
   if($value$plusargs("sqc_file=%s",sqc_file))
   fd=$fopen(sqc_file,"a");
   sqc.bintoa(sqc_value);
    //$display("before for loop %s %d",tc_op,tc_value);
   for(int i=0;i<no_probes;i++)
   sqc1={sqc1,sqc};
   sqc_val={sqc_op,sqc1};
   //$display("%s tc1 %d",tc_op,tc1);
   //$display("%s  %d",tc_op,tc_value);
   $fdisplay(fd,"%s",sqc_val);
   op=sqc_op;
   $fdisplay(fd,"%s",sqc_op);
   $fclose(fd);
 endfunction
 function mu_config(input string match_op);
   if($value$plusargs("mu_file=%s",mu_file))
   fd=$fopen(mu_file,"a");
   if(no_values==mu_count*no_probes) begin
     $fdisplay(fd,"%0d",no_probes);
     $fdisplay(fd,"%0d",mu_count);
     for(int p=0;p<no_probes;p=p+4) begin
     $display("probe value %d %d %h",p,p*mu_count,mu_value[p*mu_count]);
     for(int i=0+(p*mu_count);i<mu_count+(p*mu_count);i++) begin
     if(mu_value[i]!=0)
     if(C_PROBE0_WIDTH!=0)
      get_mu_string(mu_value[i],C_PROBE0_WIDTH,val);
     else
      get_mu_string(mu_value[i],C_PROBE_WIDTH,val);
      $display("mu_value[%d] %h %d",i,mu_value[i],p*mu_count);
      end
     for(int i=mu_count+(p*mu_count);i<(mu_count*2)+(p*mu_count);i++) begin
     if(mu_value[i]!=0)
     if(C_PROBE1_WIDTH!=0)
      get_mu_string(mu_value[i],C_PROBE1_WIDTH,val);
     else
      $display("mu_value[%d] %h",i,mu_value[i]);
      end
     for(int i=(mu_count*2)+(p*mu_count);i<(mu_count*3)+(p*mu_count);i++) begin
     if(mu_value[i]!=0)
     if(C_PROBE2_WIDTH!=0)
      get_mu_string(mu_value[i],C_PROBE2_WIDTH,val);
     else
      end
     for(int i=(mu_count*3)+(p*mu_count);i<(mu_count*4)+(p*mu_count);i++) begin
     if(mu_value[i]!=0)
     if(C_PROBE3_WIDTH!=0)
      get_mu_string(mu_value[i],C_PROBE3_WIDTH,val);
     else
      end
      end
     //foreach(mu_value[i]) begin
     // get_mu_string(mu_value[i],C_PROBE0_WIDTH,val);
    //match_value = {match_op,val};
    //  op=match_op;
    // $fdisplay(fd,"%0d",mu_value[i]);
    // $fdisplay(fd,"%s",match_value);
    // $fdisplay(fd,"%s",match_op);
   end
   $fclose(fd);
   endfunction
 initial
  begin
  $display("C_PROBE0_WIDTH %d C_PROBE1_WIDTH %d C_PROBE2_WIDTH %d C_PROBE3_WIDTH %d",C_PROBE0_WIDTH,C_PROBE1_WIDTH,C_PROBE2_WIDTH, C_PROBE3_WIDTH );
   if($value$plusargs("no_probes=%d",no_probes) && $value$plusargs("Mu_count=%d",mu_count))
   $display("probes %d no of comparators %d",no_probes, mu_count);
   else
   begin
    mu_count=1;
    no_probes=1;
   end
   if($value$plusargs("Value=%s",value)) begin
   parse(mu_value,no_values,",",value);
   if(mu_value.size()!=no_probes*mu_count) begin
   $display("mu_value %d probes %d count %d",mu_value.size(),no_probes,mu_count);
    for(int i=0;i<no_probes;i++) begin
       if(i!=0) begin
      no_values++;
      mu_value=new[mu_value.size()+1](mu_value);
      mu_value[i*mu_count]=mu_value[(i*mu_count)-1]+1;
      //$display("mu_value[i] %d mu_value %d mu_value.size %d i %d",mu_value[(i*mu_count)],mu_value[i-1],mu_value.size(),i);
      end
     for(int j=1; j<mu_count;j++) begin
      mu_value[(i*mu_count)+j]=mu_value[i*mu_count];
      no_values++;
      //$display("mu_value[i] %d mu_value %d mu_value.size %d i %d j %d",mu_value[(i*mu_count)+j],mu_value[i],mu_value.size(),i,j);
      end
      end
      end
      //$display("mu_value[i] %d i %d",mu_value[i],i);
   for (int p=1;p<no_probes;p++)
    for(int c1=0;c1<mu_count;c1++) begin
    if(p<4) begin
     mu_value[c1+(p*mu_count)]=mu_value[c1+((p-1)*mu_count)]+1;
    //$display("mu_value %h %d p %d size %d",mu_value[c1+(p*mu_count)],c1+(p*mu_count),p,mu_value.size());
     end
    else begin
     mu_value[c1+(p*mu_count)]=mu_value[c1+((p-4)*mu_count)];
    // no_values++;
    //$display("mu_value %h %d p %d ",mu_value[c1+(p*mu_count)],c1+(p*mu_count),p,mu_value.size());
    end
     end
      $display("%h no_values %d",mu_value[i],no_values);
   if($value$plusargs("Match_op=%s",match_op))
   begin
   mu_config(match_op);
   $display("match_op %s",match_op);
   end
   else
     // for(int i=mucond.next();i<mucond.num-2;i++)
      for(int i=mucond.first();i<mucond.num;i++)
     begin
       mucond=mu_cond'(i);
   if(mucond==eq)
   begin
   match_op="==";
   end
   else if(mucond==g)
   begin
   match_op=">";
   end
   else if(mucond==ge)
   begin
   match_op=">=";
   end
   else if(mucond==l)
   begin
   match_op="<";
   end
   else if(mucond==le)
   begin
   match_op="<=";
   end
   end
   end
   if ($value$plusargs ("TRIGGER_CONDITION=%d", tc_value)) begin
   if ($value$plusargs ("TC_op=%s", tc_op))
       tc_config(tc_value,tc_op);
       end
   else
      for(int i=tccond.first();i<tccond.num;i++)
     begin
     tc1="";;
       tccond=tc_cond'(i);
       if(tccond==And) begin
       tc_op="==";
       tc_value=1;
       end
       else if(tccond==Or) begin
       tc_op="||";
       tc_value=1;
       end
       else if(tccond==Nor) begin
       tc_op="==";
       tc_value=0;
       end
       else if(tccond==Nand) begin
       tc_op="!=";
       tc_value=1;
       //$display("%s %d %d",tc_op,i,tc_value);
       end
     end
   if ($value$plusargs ("SQC_CONDITION=%d", sqc_value)) begin
   if ($value$plusargs ("SQC_op=%s", sqc_op))
       sqc_config(sqc_value,sqc_op);
       end
   else
      for(int i=sqccond.first();i<sqccond.num;i++)
     begin
     sqc1="";;
       sqccond=sqc_cond'(i);
       if(sqccond==AND) begin
       sqc_op="==";
       sqc_value=1;
       end
       else if(sqccond==OR) begin
       sqc_op="||";
       sqc_value=1;
       end
       else if(sqccond==NOR) begin
       sqc_op="==";
       sqc_value=0;
       end
       else if(sqccond==NAND) begin
       sqc_op="!=";
       sqc_value=1;
       end
       $display("%s %d %d",sqc_op,i,sqc_value);
     end
  if($value$plusargs("cc_file=%s",cc_file))
  if ($value$plusargs ("DEPTH=%d", depth))
  if( $value$plusargs ("window_size_max=%d",window_size_max))
  if( $value$plusargs("window_size_min=%d",window_size_min))
  if($value$plusargs ("window_count_max=%d",window_count_max))
  if( $value$plusargs("window_count_min=%d",window_count_min)) begin
     cap_width(depth,cap_bit_width);
  if( $value$plusargs ("trigger_position_max=%d",trigger_position_max)) begin
  if( $value$plusargs("trigger_position_min=%d",trigger_position_min))
  for(int window_size=window_size_min;window_size<=window_size_max;window_size=window_size*2)
  for(int window_count=window_count_min;(window_count<=window_count_max && (window_count*window_size)<=depth);window_count++)
  if(trigger_position_max<trigger_position_min) begin
  trigger_position=window_size-1;
    fd=$fopen(cc_file,"a");
    cc_count(window_size,window_count,cc0,cc1,cc2,cc3);
    $fclose(fd);
  end //trigger_position_max
  else
  for( trigger_position=trigger_position_min;(trigger_position<=trigger_position_max && trigger_position<window_size);trigger_position++)
  begin
    $fclose(fd);
   else
  if( $value$plusargs ("trigger_position_value=%s",trigger_position_value))
  begin
  parse(trigger_value,no_values,",",trigger_position_value);
  foreach(trigger_value[i])
  if(trigger_position<window_size) begin
  trigger_position=trigger_value[i];
  $display("trigger_position %d window count %d sample count %d",trigger_position,window_count,window_size);
    $fclose(fd);
    end //window_count
  end //trigger_positio_value
  end //window_count_min
  end
  task cc_count(int window_size,int window_count,string cc0,cc1,cc2,cc3);
       $fdisplay(fd,"window_count");
       $fdisplay(fd,"%0d", window_count);
       $fdisplay(fd,"sample_count");
       $fdisplay(fd,"%0d", window_size);
       $fdisplay(fd,"trigger_position");
       $fdisplay(fd,"%0d", trigger_position);
       $fdisplay(fd,"depth");
       $fdisplay(fd,"%0d", depth);
   if(trigger_position==0) begin
    if(window_size==1) begin
     if(window_count>2) begin
       get_string((window_count-2),cap_bit_width,cc2);
       get_x_string(cap_bit_width,cc0);
       get_x_string(cap_bit_width,cc1);
       get_x_string(cap_bit_width,cc3);
       cc_sel=2;
     end
     else if(window_count==2) begin
       get_string(0,cap_bit_width,cc2);
       get_string(0,cap_bit_width,cc3);
       cc_sel=1;
     end
     else begin
       get_string((window_count-1),cap_bit_width,cc2);
       //get_x_string(cap_bit_width,cc2);
       cc_sel=0;
     end
    end
    else if(window_size>1)
        if(window_count>0) begin
      // get_string((window_size-2),cap_bit_width,cc0);
       get_string((window_size-2),cap_bit_width,cc1);
       get_string((window_size-2),cap_bit_width,cc3);
       cc_sel=3;
      end
     end
    else if(trigger_position==1) begin
     if(window_count>0)
      if(window_size==2) begin
       get_string(0,cap_bit_width,cc1);
       cc_sel=4;
      end
      else if(window_size>3) begin
       cc_sel=6;
      end
     end
    else if(trigger_position==window_size-1) begin
      if(window_size>3)
       get_string((trigger_position-2),cap_bit_width,cc0);
       cc_sel=5;
    end
    end
    else if(trigger_position>1)
      if(window_size>3)
       cc_sel=7;
    end
    $fdisplay(fd,"value");
    $fdisplay(fd,"%s", {"==",cc0});
    $fdisplay(fd,"%s", {"==",cc1});
    $fdisplay(fd,"%s", {"==",cc2});
    $fdisplay(fd,"%s", {"==",cc3});
    $fdisplay(fd,"%d",cc_sel );
   endtask
   initial
   #20 $finish;
endmodule
