  2. Functional Verification
  3. can't import uvm_ml for using sv test with e component
  • Subscribers 68
  • Views 4769
zeevg
zeevg over 3 years ago
In my test I have : import uvm_ml::*;
after compilation with : xrun -V93 +UVM_TESTNAME=test_cosim -ml_uvm ...
I got an error:
xmvlog: *E,NOPBIND (...) package uvm_ml could not be bound
I run with xrun(64) 21.03-s001
How can I enable runing in multilanguage?
  • StephenH
    StephenH over 3 years ago
    Hello Zeev.
    According to the docs here, you should be importing ml_uvm::*, not uvm_ml::*.
  • zeevg
    zeevg over 3 years ago in reply to StephenH
    Thanks stephen,
    I imported ml_uvm and it worked.
    Now I got an error on "uvm_ml_create_component" :
  • zeevg
    zeevg over 3 years ago in reply to zeevg
    I tried it with ml_uvm:: and without it as mentioned in support.cadence.com/.../techpubDocViewerPage
  • StephenH
    StephenH over 3 years ago in reply to zeevg
    Ah, so you're trying to use the newer "OA" library! There are two, a legacy "ml_uvm" package and a newer Open Architecture one, confusingly named uvm_ml. In this case, revert the package name to what you had originally: uvm_ml.
    Did you use the other required option from that page, i.e. "-uvmhome CDNS-1.2-ML" so that it picks up the ML-enabled UVM library?
  • zeevg
    do I have to use in xrun command the "-ml_uvm" in addition to "-uvmhome CDNS-1.2-ML"?  I used them both and got an error
  • StephenH
    To be honest, I'm a bit rusty on this, but it looks like -ml_uvm is the legacy flow and if you're using the OA version then it's the -uvmhome plus -uvmtop to specify which language sits at the top of the testbench hierarchy. So don't use -ml_uvm.
