  2. Functional Verification
  3. HAL linting with parameters/generic
  • Subscribers 68
  • Views 7755
lanix
lanix over 3 years ago
I am on the design of a generic IP and as usual I wanted to check my code with HAL but unlike usual, I have a parametrized design, I mean I have a lot of RTL that are include in "if generate" (Verilog) and depending on module parameters values. The issue is that HAL is analysing (as far as I know) only the set of parameter value that I gave to him and not all the possibilities, so I must launch HAL multiple times with all possible values for it to analyse all my RTL.
Is there a way to do that in a better way ?
To be noted that I also have a non-regression test with all the possible values, so if HAL could aggregates multiple simulations (as for IMC that does it for code coverage), it would be great too.
Jeremie
  • StephenH
    StephenH over 3 years ago +1
    Hello Jeremie. HAL uses the simulation snapshot compiled by Xcelium, so it will only inspect the parts of the design that were active based on the elaborated parameter values. You can run HAL by adding…
  • StephenH
    Hello Jeremie.
    You can run HAL by adding "-hal" to your xrun command that you would use for simulation, so you could in theory run HAL on all your configurations quite easily.
    Note that there isn't a way to "merge" the HAL reports in the tool flow.
    Finally, HAL is a legacy tool now, it was replaced by Jasper SuperLint a while ago, so you might want to consider moving to the new tool.
  • lanix
    lanix over 3 years ago in reply to StephenH
    Thanks for the quick answer. I will stay by running HAL on all configurations, one by one.
    Jasper is under study internally and we should migrate to it shortly.
  • ckomar
    ckomar over 3 years ago in reply to lanix
    hi Jeremie - I run the Jasper product engineering team and would be interested to hear more about your requirement. You can reach me at my login name at cadence.com. Thanks - Chris
