  2. Functional Verification
  3. How can I exclude simulation failed test cases when coverage...
  • Subscribers 68
  • Views 10480
How can I exclude simulation failed test cases when coverage is merged without not using vManager?
Jason Lee Chet
Jason Lee Chet over 3 years ago
I build up the environment for automatically extracting coverage.
I want to exclude failed test cases when simulation. For this, I think that coverage database has test result pass or fail and then when merging it using imc passed test cases is merged only. But I cannot find proper options related coverage. I don't know if this is feasible
Because the vManager has similar feature, I think that the method described above is feasible.
If anyone knows a solution, please share.
Jason Lee
  • StephenH
    StephenH over 3 years ago
    The coverage files don't record pass/fail status, because vManager doesn't rely on coverage files for test status (tests can be anything, e.g. lint tools, synthesis, etc).
    If you want to report coverage only for passing tests without using vManager, you will have to enhance your own script environment to track which coverage files relate to the passing tests, then only merge those coverage files in IMC.
  • Jason Lee Chet
    Jason Lee Chet over 3 years ago in reply to StephenH
    Thank you for your response. This is helpful for me.
