  2. Functional Verification
  3. Merge command error
  • Subscribers 68
  • Views 12177
Merge command error
Rakeshp97
Rakeshp97 over 3 years ago
When I tried to merge all my coverage ".ucd" files generated in IMC , its showing this sort of warning :
*W,MGURTS: The merge command could not resolve the run specification cov_work/scope/test_01. Verify the existence of a UCD file in the specified run, and rerun the command.
*W,MGURTS: The merge command could not resolve the run specification cov_work/scope/test_02. Verify the existence of a UCD file in the specified run, and rerun the command.
*W,MGURTS: The merge command could not resolve the run specification cov_work/scope/test_03. Verify the existence of a UCD file in the specified run, and rerun the command.
*I,MERGL1: No Simulation coverage databases found in the runs.
*I,MERGL1: No Specman coverage databases found in the runs.
Total conflicts during target model creation: 0
Total items not merged : 0
Total runs not considered during target model creation: 0
Total runs not merged : 0
Coverage engine version: 21.09-s012
I used the command in the following way :
1. imc -batch
2.merge test_01 tst_02 test_03 -out all
  • StephenH
    StephenH over 3 years ago
    IMC assumes that your coverage files are stored in a specific directory structure, unless you give the full path to the directory containing the UCD file.
    Thus "test_03" is translated to "./cov_work/scope/test_03/" and IMC expects to fin the UCD file under that directory path.
    If you ran your simulation with any if the options "-covworkdir" or "-covscope" then the "cov_work" or "scope" parts of the directory name will be different.
    The simplest thing is to give the full paths in the IMC command.
  • Rakeshp97
    Rakeshp97 over 3 years ago in reply to StephenH
    Hi Stephen,
    But my coverage UCD files are already there inside /cov_scope/scope/test_*/*.ucd
  • StephenH
    StephenH over 3 years ago in reply to Rakeshp97
    Apparently IMC can't find them. Since there doesn't seem to be a general problem here for other users, I suspect something's wrong in your setup.
    Please share the results from running the command "ls -l cov_work/scope/test_03" in the shell / terminal where you had launched IMC from.
