  2. Functional Verification
  3. SystemVerilog task() output signal does not have correct...
  • Subscribers 68
  • Views 14805
SystemVerilog task() output signal does not have correct value
HoWei
HoWei over 3 years ago
I started recently with SystemVerilog (lets say Verilog in general) and I am trying to create a "task()".
I am using the Virtuoso/Xcelium AMS environment and want to generate a pulse with configurable length.
I am using 2 internal signals in the module "mysignal" and "mysignal2".
"mysignal" is directly assigned with a value inside the task().
"mysignal2" shall get the value from the task() output signal assignment.
Here my code:
`timescale 1 ns / 1 ns
module clk_gen_SV_stim (GEN_ADCCLK, GEN_CLKGEN_ADC_RATE,
GEN_CLKGEN_BYPASS, GEN_CLKGEN_DIV_F, GEN_CLKGEN_EN
output logic GEN_CLKGEN_DIV_F;
output logic GEN_CLKGEN_ADC_RATE;
output logic GEN_CLKGEN_EN = 1'b0;
output logic GEN_ADCCLK;
output logic GEN_CLKGEN_BYPASS;
logic mysignal = 1'b0;
logic mysignal2 = 1'b0;
// task
task pulse( input time length, output intsig);
mysignal = 1'b1;
intsig = 1'b1;
$display("intsig =%b at %t",intsig, $time() );
#length
mysignal = 1'b0;
intsig = 1'b0;
//GEN_CLKGEN_EN = 1'b0;
endtask : pulse
//start with state 0
initial begin
#5ns
pulse(.length(20ns), .intsig(mysignal2)); //call with argument mapping
#25ns
pulse(20ns, mysignal2); //call with positional argument
end
endmodule
The problem is, that "mysignal2" never changes its value.
But internally in the task() the local "intsig" is assigned properly:
Does anyone know why, and whats wrong with the "mysignal2" assignment ?
Ar do I have wrong expectations on "mysignal2" behaviour ?
  • StephenH
    StephenH over 3 years ago
    A task's output arguments are copied by value at the end of the task's execution. If you want the changes to happen instantly, make them "ref" instead of "output".
  • HoWei
    HoWei over 3 years ago in reply to StephenH
    I tried and receive a compile error:
    I am not sure I have done that correctly, as i do not (yet) know the difference between ref and output.
    I am wondering when using "output" at what time the assignement to "mysignal2" will happen ?
  • StephenH
    StephenH over 3 years ago in reply to HoWei
    Add the "automatic" qualifier to the task:
    task automatic pulse (input time length, ref intsig);
    BTW, one would typically use a clocking event rather that an actual time, unless your design is an asynchronous one. Clocked stimulus is more efficient to simulate.
  • HoWei
    HoWei over 3 years ago in reply to HoWei
    Great THX - now it behaves as I expected !
