  2. Functional Verification
  3. Create image from vcd file
  • Subscribers 70
  • Views 11389
PontusT
PontusT over 3 years ago
Hello!
Is there a way to convert VCD file to an image using a script for automated mixed signal simulation results?
Using Simvision I can print window and get the job done, but I would want to automate the process using a script.
    Andrew Beckett over 3 years ago +1
    Moved this into the Functional Verification Forum as somebody there may know if there's a way of doing this. There's an old enhancement request for SimVision to directly save images (CCR 83415 - maybe…
  • Doug Koslow
    Doug Koslow over 3 years ago in reply to Andrew Beckett +1
    Hi Andrew, Indeed, there is a SimVision "waveform print" command that will output the waveforms to postscript. The documentation reference for it is here: https://support.cadence.com/apex/techpubDocViewerPage…
    Moved this into the Functional Verification Forum as somebody there may know if there's a way of doing this. There's an old enhancement request for SimVision to directly save images (CCR 83415 - maybe a Jira now), but I guess it could be done if you could use a Tcl command to print the window to PostScript and then externally convert the PostScript to a png file. I don't know (as I don't know SimVision Tcl well enough) whether there is a way of doing the Print Window from Tcl - hence moving this into a forum where there's a greater chance of somebody knowing.
    You may be better off contacting customer support.
  • Doug Koslow
    https://support.cadence.com/apex/techpubDocViewerPage?path=SimVisTclCmds/SimVisTclCmds22.09/cmd_ref.html#83053
    There is also a support article on using it here:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000007MhEiUAK&pageName=ArticleContent
    Thanks.
    - Doug
  • PontusT
    PontusT over 3 years ago in reply to Doug Koslow
    Great! Thanks a lot!
