  2. Functional Verification
  3. Jaspergold -- Net does not have a driver
  • Subscribers 70
  • Views 3515
Vivek Kakkireni
Vivek Kakkireni over 3 years ago
Hi
In Jasper gold >>>Even after assuming a value for the declared signal --- Seeing warning as net "signal name" does not have a driver
ex_signal[4] ---> ex_signal[0] ,ex_signal[1], ex_signal[2], ex_signal[3]
If we represent a signal with depth of 4 and width of 1 --- it should be as represented as above right...?
But if i declare a signal as above im seeing a "Net does not have a driver" only for ex_signal[0] ----- No warnings for the rest of the positions like ex_signal[1/2/3] --- Im not assuming any value for the array signal but seeing warning only for the 0th position of the signal
  • ErikSeligman
    ErikSeligman over 3 years ago
    Hi Vivek--  Numerous messages in the tool are reported on a representative bit rather than each bit of an array, in order to avoid spamming the display/log with redundant notifications.   Please contact your AE or check out support.cadence.com for more details on this particular warning type.    Thanks!
