  2. Functional Verification
  3. Can queues be used to drive RTL?
  • Subscribers 68
  • Views 10331
shareefj
shareefj over 3 years ago
This may well be a case of my not being able to see the wood for the trees or generally doing something stupid, but I thought I'd ask anyway.
I'm trying to interface a bus driver with some DPI code and thought that using a queue would be the best way.  What I have on the DPI side is a function that is called when new data is available to be pushed onto the queue.  On the RTL side, I've got a module with a FIFO interface and data is popped off the queue as it is loaded into the receiving downstream flop.  So something like the following:
bit [31:0] queue[$];
function push_back;
  input bit [31:0] value;
  queue.push_back(value);
endfunction
always_ff@(posedge clk) begin
  if(fifo_pop)
    queue.pop_front();
end
assign din = queue[0];
  if (fifo_pop)
    capture_r <= din;
end
What I'm seeing is that the queue is updated before din has been captured in the receiving flop.  Is that expected and if so, what should I be doing here?  I've not done a load of DPI work before and haven't seen too many examples of how to cleanly drive an interface like this.
Thanks.
  • shareefj
    Just as a side note, modifying the above example such that the pop and assignment happen on the same line in the same always block works.  I just can't do that in my real code due to hierarchy.  Putting in a simple one entry FIFO that bridges between DPI and RTL seems to work though.
    always_ff @(posedge clk) begin
      if (fifo_pop)
        capture_r <= queue.pop_front();
    end
  • StephenH
    StephenH over 3 years ago
    At a glance, I think this is mainly due to a race between your two clocked processes and you might even find the behaviour changes if you swap the declaration order of those.
    It's a little unusual to use queue.pop_front() without using the popped value, so I think your later post where you assign the popped value to capture_r is more "normal" use of the construct. Note also that the pop_front() is a blocking action, just like a blocking assignment that you would use in combinational logic, so by using it directly in a clocked process in your first example, you're making a blocking assignment in a clocked process. The normal rules for coding a clocked process are that you must only use non-blocking assignments, to avoid races with combinational logic that uses only blocking assignments.
  • shareefj
    shareefj over 3 years ago in reply to StephenH
    A little unusual is a good description.  Given the rest of your comment, is there any other way I can drive a combinational net/bus from a queue?  Or is that just bad practice and I should always be popping into some sequential logic that handles driving?
  • StephenH
    StephenH over 3 years ago in reply to shareefj
    Most testbenches would be driving the wires from a clocked process using either a clocking block or a non-blocking assignment, I don't think I've ever seen someone connecting a queue element directly to a signal until now. Whether this counts as bad practice, I'm not sure - SV provides an almost infinite number of ways to do anything, you just have to be really careful about the scheduling semantics if you deviate from the conventional sequential / combinational driver patterns.
  • shareefj
    Thanks Stephen.
