  2. Functional Verification
  3. Error : lps_1801 elaboration : *E,MTOMDU : More than one...
  • Subscribers 69
  • Views 7219
Error : lps_1801 elaboration : *E,MTOMDU : More than one unit matches 'TESTBENCH'
Zero00
Zero00 over 3 years ago
I am listening Low power simulation with IEEE 1801 UPF v22.09 Module 04 : simulating a UPF based low power RTL design
Example of module4 in nano CPU of DebuggingLPS/examples attempted to demonstrate.
However, I tried to run xrun using the example, this error occurred.
xmelab : *E,MTOMDU : More than one unit matches 'TESTBENCH'
I want to solve this problem and demonstrate this example.
single step
xmvlog nano.v testbench.v
xmelab -mess -access +rwc -timescale 1ns/1ps -lps_1801 nano.upf worklib.TESTBENCH
xmsim TESTBENCH
multiple step
xrun -messages -lps_stime 1ns -lps_verbose 1 -lps_logfile lps.log -gui -input input.tcl worklib.TESTBENCH
  • StephenH
    StephenH over 3 years ago
    Don't mix 3-step (xmvlog/xmebal/xmsim) and single-step (xrun) in the same directory. Ideally just use xrun.
    Try this command:
    xrun -clean -lps_stime 1ns -lps_verbose 1 -lps_logfile lps.log -gui -input input.tcl nano.v testbench.v -lps_1801 nano.upf
  • Zero00
    Zero00 over 3 years ago in reply to StephenH
    Now I use xrun option but error is same.
    Thank you for your answer
  • StephenH
    StephenH over 3 years ago in reply to Zero00
    No, that's a different error, which is telling you that the TESTBENCH module has no power domain information in the UPF.
  • Zero00
    Dear StephenH
    I'm currently studying UPF, so I don't know yet.
    As shown in the cadence lecture, I want to observe the waveform with gui, but the TESTBENCH snapshot is not currently available.
    The top module is configured as TESTBENCH, and the upf file is also set to set_design_top TESTBENCH as TESTBENCH.
    I don't know why snapshot doesn't come out.
    The current example is in practice by copying <install_dir>/XCELIUM/doc/DebuggingLPS/examples to the Desktop folder.
    I don't know how to solve this problem.
    Thank you for your answer.
  • Nasser
    Nasser over 3 years ago in reply to Zero00
    Can you share a snippet of your UPF file? You must be missing a default power domain specification in the UPF. In order to fix it you can do multiple things:
    1) Define your set_design_top like this:
    set_design_top TESTBENCH -testbench
    set_design_top <put the name of the design top here>
    2) You can also add a power domain definition:
    create_supply_set SSD
    create_power_domain PDD -include_scope -supply {primary SSD}
  • Zero00
    Zero00 over 3 years ago in reply to Nasser
    thank you i finally solved it!!
    I missed default '-testbench' option but inserted this option to solve this problem.
