  2. Functional Verification
  3. why my xrun does not compile UVM library package automatically...
  • Subscribers 68
  • Views 13308
why my xrun does not compile UVM library package automatically?
galenxiao
galenxiao over 3 years ago
I have a very small module level UVM environment. I add "-uvmhome CDNS-1.1d" option with xrun, but it report some compile error. It seems that xrun does not compile UVM library automatically. I use some UVM macros, xrun does not recognize those macros. I think it's because xrun does not pre-compile UVM library. When I use VCS with same file, it can pass. It seems that VCS will pre-compile UVM lib before compile user code, so it does not report error.
Below is my xrun log which report compile error:
xrun(64): 20.09-s007: (c) Copyright 1995-2020 Cadence Design Systems, Inc.
TOOL: xrun(64) 20.09-s007: Started on Apr 23, 2023 at 10:10:41 CST
xrun
-64bit
+notimingchecks
-licqueue
-seed random
+tcl+dump.tcl
-access +rw
-sv
+libext+.v+.sv
-uvm
-uvmhome CDNS-1.1d
-svrnc fatal
-f file.f
+incdir+../include+../src+../env+../tests+../hdl
/home/scripts/python_study/uvmgen/templates/bds_env/tests/bds_env_tb_mod.sv
/home/scripts/python_study/uvmgen/templates/bds_env/hdl/bds_env_top.sv
+UVM_TESTNAME=bds_env_test
Compiling UVM packages (uvm_pkg.sv cdns_uvm_pkg.sv) using uvmhome location /tools/cadence/XCELIUM2009/tools/methodology/UVM/CDNS-1.1d
file: /home/scripts/python_study/uvmgen/templates/bds_env/tests/bds_env_tb_mod.sv
interface worklib.mbus_intf:sv
errors: 0, warnings: 0
interface worklib.mbus_slave_intf:sv
`uvm_register_cb(mbus_master_monitor,mbus_master_monitor_callbacks);
xmvlog: *E,NOTDIR (../src/mbus_master_agent_mbus_master_monitor.sv,52|18): `uvm_register_cb: not a recognized directive or macro [2.7.3][16.3.1][16(IEEE)].
(`include file: ../src/mbus_master_agent_mbus_master_monitor.sv line 52, `include file: ../include/mstr_slv_src.incl line 2, `include file: ../include/bds_env.sv line 11, `include file: ../env/bds_env_ral_env.sv line 7, file: /home/scripts/python_study/uvmgen/templates/bds_env/tests/bds_env_tb_mod.sv line 12)
  • StephenH
    StephenH over 3 years ago
    You can actually see the messages from xrun saying that it is compiling the UVM library, so your assumption about the problem is incorrect.
    What's wrong is that your source code is failing to include the uvm_macros.svh file. Try adding the following line to your code:
    `include "uvm_macros.svh"
