  2. Functional Verification
  3. System Verilog: always @( * ) is not working, but explicit...
  • Subscribers 68
  • Views 16907
System Verilog: always @( * ) is not working, but explicit declaration always @( s1, s1, s3) is working
HoWei
HoWei over 3 years ago
In my code I am using the following sensitivity list declaration.
Problem: This code never enters the always @( * )  block - thus the supply check always fails (supplyOk=0):
//checking supply
`ifdef SUPPLYCHKOFF
   logic supplyOk = 1;
`else
  logic supplyOk = 0;
  always @( * ) begin
    $display("TIO MUX GATE always block was triggered");
    //range check
    if( VSS inside {[minGND : maxGND]}) supplyOk = 1;
    else supplyOk = 0;
end
`endif
BUT when the sensitivity list includes the explicit inputs, then it is working as expected and sets "supplyOk=1":
//checking supply
`ifdef SUPPLYCHKOFF
   logic supplyOk = 1;
`else
  logic supplyOk = 0;
  always @( ATB_TG_EN, ATB_TG_EN_B, VSS, TG_in ) begin
    //range check
    else supplyOk = 0;
end
`endif
Does anyone have an explanation for this behavior ?
I am using  ICADVM20.10.310 with XCELIUM22.09.002.
This supply-check code snippet is used in many other models and working there perfectly fine. Only in this model, it does not - and I do not find the reason.
I would like to attach the complete model file, but did not find a way to do it in this forum.
  • HoWei
    Could the problem be, that I do have multiple "always @( * )" blocks inside this module ?
    Because I do have another condition and 'ifdef condition in the functional part of the module - below is the complete module code.
    This code uses 'ifdef conditions to allow SV-RNM-bidirectional nets to be run in XCELIUM as well as in Synopsys VCS (just FYI):
    //systemVerilog HDL for "CROCODILE", "atb_tiomux_tgate" "systemVerilog"
    import CONTI_SV_PACKAGE::*;
    `ifdef XCELIUM
    import cds_rnm_pkg::*; //for Cadence tool-chain
    `elsif VCS
    import snps_msv_nettype_pkg::*;//for Synopsys tool-chain
    `endif
    `define T wreal4state //nettype to resolve net value
    module atb_tiomux_tgate ( TG_out, VSS, ATB_TG_EN, ATB_TG_EN_B, TG_in );
    inout `T TG_in;
    input logic ATB_TG_EN;
    inout `T TG_out;
    input logic ATB_TG_EN_B;
    input `T VSS;
    //checking supply
    `ifdef SUPPLYCHKOFF
    logic supplyOk = 1;
    `else
    logic supplyOk = 0;
    //always @( ATB_TG_EN, ATB_TG_EN_B, VSS, TG_in ) begin
    always @( * ) begin
    //range check
    else supplyOk = 0;
    end
    `endif
    //internal control logic
    bit control;
    assign control = ( (ATB_TG_EN && ~ATB_TG_EN_B) === 1'b1 && supplyOk==1 ) ? 1'b1 : 1'b0; //case comparison resolves to 0 if 'X or 'Z
    `ifdef XCELIUM
    //internal nets to store the external resolved value
    `T TG_in_i = `wrealZState; //this initial value is essential for proper function
    `T TG_out_i = `wrealZState;
    // bidirectional functionality
    assign TG_in = ( control==1'b1) ? TG_out_i : `wrealZState ;
    assign TG_out = ( control==1'b1) ? TG_in_i : `wrealZState ;
    //on a change, check the sense the external driver status
    always @( * ) begin
    $cged(TG_in, TG_in_i); //store outside resolved value on internal net
    $cged(TG_out, TG_out_i);
    end
    `elsif VCS
    tranif1(TG_in, TG_out, control);
    `endif
    endmodule
  • StephenH
    StephenH over 3 years ago in reply to HoWei
    Since you seem to be using SystemVerilog, please replace the always @(*) with always_comb. The semantics of the always @(*) are not well defined and can cause incompatible resutls where different vendors have implemented the feature differently due to differing interpretations of the spec. always_comb is much more precisely specified in the SV standard and should be more portable.
  • HoWei
    HoWei over 3 years ago in reply to StephenH
    Thanks Stephen for this hint - I will have a look and try to understand and use this is future in system verilog.
    BUT the real issue is that I missunderstood the "always @ (*)" functionality.
    So far (in my short verilog modelling career) had the understanding that the "*" means "ALL INPUTS IN THE MODULE"  - but it acutally means "ALL INPUTS INSIDE THE ALWAYS BLOCK" - which is a completely different functionality.
    I now changed my code which will assign the "supplyOk" continously as combinatorial logic - do you see any issues with such a implementation - compared to the above approach with "always..." :
    inout `T TG_in;
    inout `T TG_out;
    input `T VSS;
    //checking supply
    `ifdef SUPPLYCHKOFF
       logic supplyOk = 1;
    `else
       logic supplyOk;
       assign supplyOk = VSS inside {[minGND : maxGND]};
    `endif
  • tpylant
    tpylant over 3 years ago in reply to HoWei
    Yes, your new understanding is correct -- the always @(*) or always_comb refers to all signals on the RHS of expressions inside the always procedural block. The big difference between @(*) and comb is that always_comb executes at time 0 regardless of the signal values whereas always@(*) waits until there is a signal change before executing for the first time.
    The code changes you made should provide the simplest solution for the functionality that you want.
    Tim
  • HoWei
    HoWei over 3 years ago in reply to tpylant
    Thanks for confirmation.
    As I try to understand the differences between "always_comb / _latch /_ff" I think the differences among those functions are only relevant when the code will be synthesized - and it will give error if it cannot be synthesized as declared by either _comb / _ff or _latch.
    In my case, I am doing AMS modelling and verification/testbenches only an do not care about synthesizability of the module.  Thus can I still use the "always  @*" function and by that avoid any error which might be caused due to non-synthesizability ?
    Or does would this cause other issues ?
    I indeed see the advantage of the initial execution of the new "always_comb/latch/ff" function.
