  2. Functional Verification
  3. Irun error MXINDR with a verilog PLL model wrapper written...
  • Subscribers 68
  • Views 8936
Irun error MXINDR with a verilog PLL model wrapper written in VHDL, any way to workaround?
mxlusereight
mxlusereight over 3 years ago
Hi Cadence,
I have a VHDL wrapper of a PLL behavior model. The VHDL routes XO output CLK_P & N to the PLL as differential input.
In the PLL model the same signal goes through 7 hierarchies to a leaf cell where the final line is "tranif1 #(1*5) tgate (OUT,IN,en_diff);".
The PLL model is written such that in layer 2K+1 of hierarchy the CLK_P & N are defined as INOUT, while on layer 2K it is defined as input. VCS seemed to work fine and generate a schematic below.
xcelium_21.09.s007 gave the following error,
xmelab: *E,MXINDR: VHDL port of mode IN, :a:b:c:PLL_shell_inst<local>FREFCMLN (/dir/rtl/pll_wrap-rtl-a.vhd: line 27), is connected below to a Verilog port, :a:b:c:d_inst.FREFCMLN (/dir/beh/PLL_shell.v: line 31), with drivers.
Are there any switches in xcelium to make it work?
Thank you in advance.
  • StephenH
    StephenH over 3 years ago
    You could try compiling and elaborating with -relax or -io_port_relax. Without an actual runnable example of your code it's hard to tell if these would help. I did try to build something based on your description but couldn't reproduce the same error. (in fact, what I built was elaborating just fine with inout ports).
  • mxlusereight
    mxlusereight over 3 years ago in reply to StephenH
    Thank you very much! I will try that.
    I managed to use this flag "-nomxindr".
