  2. Functional Verification
  3. Xcelium waveform dump into custom directory
  • Subscribers 68
  • Views 11785
DamianRRR
DamianRRR over 3 years ago
Does anyone know if there is an option in Xcelium to change the location of the waveform dump? Currently in my tcl script I use
database -open -shm -into waves.shm waves -default
and this way I have the waves in the "work" directory.
Do you know if it is possible to change this directory?
  • StephenH
    StephenH over 3 years ago
    The -into switch accepts a file path. You specified "waves.shm" in the current directory, but if you prefix the name with a directory path, that will be used.
