  2. Functional Verification
  3. Not able to Invoke XRUN
  • Replies 12
  • Subscribers 68
  • Views 23039
adtdeep
adtdeep over 3 years ago
I had installed XCELIUM in my personal computer, license manager is installed in my college server. i have set all the paths and env variables for using this tool but when i invoke xrun command its showing "xrun: command not found."
Deepak B
  • StephenH
    StephenH over 3 years ago in reply to jgonzo +1
    Josef, you've made the same mistake as Deepak. You have invoked the IC 6.1.8 version of checkSysConf, which is very old and isn't aware of RHEL8 (notice the screen output tells you it's picking the definition…
  • StephenH
    I don't know what would cause that error. The /eda/cadence/2021-22/RHELx86/XCELIUM2209/tools/bin/xrun file is a symbolic link to a compiled ELF binary, if you do "ls -l /eda/cadence/2021-22/RHELx86/XCELIUM2209…
  • StephenH
    Deepak, perhaps you could share the settings you used for your PATH variable? It's hard to debug without any details.
  • adtdeep
    adtdeep over 3 years ago in reply to StephenH
    Hi Stephen,
    The below is the env and path variable i have set in cshrc file and sourced it:
    setenv LM_LICENSE_FILE 5280@internal_ip
    setenv CDS_LIC_FILE 5280@internal_ip
    setenv XCELIUMHOME /home/install/XCELIUM2209
    set path = ( $XCELIUMHOME/tools.lnx86/dfII/bin $XCELIUMHOME/share/bin $XCELIUMHOME/bin $XCELIUMHOME/tools/bin $XCELIUMHOME/tools/dfII/bin $XCELIUMHOME/tools.lnx86/bin $XCELIUMHOME/tools.lnx86/dfII/bin $path)
    Deepak B
  • StephenH
    StephenH over 3 years ago in reply to adtdeep
    Normally I would only add $XCELIUM_HOME/tools.lnx86/bin to the path or PATH variable, the rest of those entires you quoted should not be required.
    It's possible that your personal machine doesn't have a compatible OS, or is missing some key components of the OS. For example I often see that users don't have "ksh" installed, and there are some commands within Xcelium that require ksh.
    You can try running the command "checkSysConf XCELIUM2209" which should report a bunch on checks to see if your OS has the required components installed. Check and fix any "FAIL" messages. Eventually you need to see a message similar to this before Xcelium will work:
    Normal exit. This workstation (foo) status is: PASS
    Host foo has a Cadence supported Linux configuration.
  • adtdeep
    i got the below response when i ran the command,
    [deepak.mee23@server install]$ checkSysConf XCELIUM2209
    [Copyright 2002-2022] Cadence Design Systems, Inc. All rights reserved.
    This  program and online  documentation  may not be copied, modified,
    re-published, uploaded,  executed, or  distributed in any way, in any
    medium, whether in whole or in part, without prior written permission
    from Cadence Design Systems, Inc.
    ============== checkSysConf:  Version 3.51 ====================
    Configuration checks failed on this workstation (server), status is: FAIL
    This operating system version '8.0WS' is not supported
    If you believe you are running a supported OS then check that
    the OS version directory exists in the data directory:
    /home/install/IC618/share/patchData/Linux/x86_64
    Exiting checkSysConf ... Good-bye
    iam currently using RHEL8 and the college lab system which was already working also is throwing the same response but iam able to invoke the xrun command there.
    Deepak B
  • StephenH
    It looks like you're running checkSysConf from a different tool install path (/home/install/IC618/).
    Xcelium version 22.09 does support RHEL 8, and thus the right checkSysConf should accept that as a valid platform. The IC618 tool doesn't appear to support RHEL8 (according to the info on https://downloads.cadence.com/ESDWeb/Welcome.eo) so that might explain your results.
    Whilst debugging issues I would recommend that you run checkSysConf from the Xcelium install path.
  • adtdeep
    Hi Stephen,
    Right now i checked by running checkSysConf from the Xcelium install path and iam getting the status as "PASS" and a message "Host localhost.localdomain has a cadence supported linux configuration"
    but still when i run xrun command iam getting command not found.
    Deepak B
  • adtdeep
    adtdeep over 3 years ago in reply to adtdeep
    Thanks after installing libssl it worked.
    Deepak B
  • jgonzo
    jgonzo over 3 years ago in reply to StephenH
    Hello Stephen,
    I have a same problem with XCELIUM with IC_6.1.8.270_RHELx86 on AMD machine.
    in .bashrc linked XCELIUM with this command
    source /eda/cadence/2021-22/scripts/XCELIUM2209.sh
    which is doing:
    export CDS_XCELIUM=/eda/cadence/2021-22/RHELx86/XCELIUM2209
    export PATH="${PATH}:${CDS_XCELIUM}/bin:${CDS_XCELIUM}/tools/bin:${CDS_XCELIUM}/tools/cdsgcc/gcc/bin"
    alias help_cds_xcelium='$CDS_XCELIUM/tools/cdnshelp/bin/cdnshelp &'
    # xrun, simvision, xmvhdl, xmvlog, xmsc, xmelab, xmsim, xmls, xmhelp, xfr, xmxlimport
    when I try in folder /eda/cadence/2021-22/RHELx86/XCELIUM2209/tools.lnx86/bin
    I get
    /eda/cadence/2022-23/RHELx86/IC_6.1.8.270/share/patchData/Linux/x86_64
    I have ksh installed together with all recommended patches (https://support.cadence.com/apex/ArticleAttachmentPortal?pageName=ArticleContent&id=a1Od000000051rO&pageURL=COSComputingPlatforms&oMenu=DocumentViewer%20Computing%20Platforms)
    for ssl I have:
    yum list installed | grep ssl
    apr-util-openssl.x86_64                            1.6.1-6.el8                                                 @rhel-8-for-x86_64-appstream-rpms
    compat-openssl10.x86_64                            1:1.0.2o-4.el8_6                                            @rhel-8-for-x86_64-appstream-rpms
    openssl.x86_64                                     1:1.1.1k-7.el8_6                                            @rhel-8-for-x86_64-baseos-rpms
    openssl-devel.x86_64                               1:1.1.1k-7.el8_6                                            @rhel-8-for-x86_64-baseos-rpms
    openssl-libs.x86_64                                1:1.1.1k-7.el8_6                                            @rhel-8-for-x86_64-baseos-rpms
    openssl-pkcs11.x86_64                              0.4.10-2.el8                                                @anaconda
    xmlsec1-openssl.x86_64
    Could it be connected with the fact it is a AMD? With intel processors with same RHEL8 installation XCELIUM is running.
    Thank you
    Best regards
    Josef
  • StephenH
    Josef, you've made the same mistake as Deepak. You have invoked the IC 6.1.8 version of checkSysConf, which is very old and isn't aware of RHEL8 (notice the screen output tells you it's picking the definition file from /eda/cadence/2022-23/RHELx86/IC_6.1.8.270/share/patchData/Linux/x86_64.
    This is most likely to be caused by you adding Xcelium to the end of your PATH instead of the start - this means that the binaries in the Xcelium install will only be picked up if there's no same-named binary elsewhere int he PATH. I would usually add new programs to the start of the PATH to ensure they are picked up in preference to any other tools.
    If you run the Xcelium copy of checkSysConf, it should be happy with that OS version.
    As regards the choice of Intel or AMD CPU, Xcelium should not be sensitive to this difference, both vendors should be fine.
  • jgonzo
    Thank you, I wasnt aware of that. I was missing motif package which is not written in https://support.cadence.com/apex/ArticleAttachmentPortal?pageName=ArticleContent&id=a1Od000000051rO&pageURL=COSComputingPlatforms&oMenu=DocumentViewer%20Computing%20Platforms
    so now checkSysConf PASS
    Should I paste here the full results?
    but I am still getting
    xrun -version
    bash: /eda/cadence/2021-22/RHELx86/XCELIUM2209/tools/bin/xrun: No such file or directory
