  2. Functional Verification
  3. preprocessor directive
  • Subscribers 68
  • Views 6985
daivon
daivon over 3 years ago
In e code one may use #ifdef <DEFINE_NAME> for preprocessor directive.
if a given name is defined, it uses the attached code.
Is there a syntax for:
#ifdef <DEFINE_NAME> == TRUE?
  • StephenH
    StephenH over 3 years ago +1
    The preprocessor directives are limited to testing whether the define label is set or not, it cannot perform conditional tests.
  • StephenH
