  2. Functional Verification
  3. When running upf simulation power net is stuck at 0
  • Subscribers 69
  • Views 8892
2tojohny
2tojohny over 2 years ago
I have the following upf constructs:
create_power_domain PD_TOP \
         -include_scope
create_power_domain    PD_V1P8_AVDD \
       -elements { A/B }
create_supply_port NET_V1P8_AVDD \
         -direction in \
         -domain PD_TOP
create_supply_port AGND \
         -direction in \
         -domain PD_TOP
create_supply_net AGND \
         -domain PD_TOP
create_supply_net NET_V1P8_AVDD \
         -domain PD_TOP
connect_supply_net NET_V1P8_AVDD \
         -ports { NET_V1P8_AVDD A/B/AVDD_pin }
connect_supply_net AGND \
        -ports { AGND A/B/AGND_pin }
create_supply_set ss_V1P8 \
         -function { power NET_V1P8_AVDD } \
         -function { ground AGND }
associate_supply_set ss_V1P8 \
         -handle PD_V1P8_AVDD.primary
add_power_state PD_V1P8_AVDD.primary \
        -state ON { -supply_expr {power == \
        `{FULL_ON, 1.8} && ground == `{FULL_ON, 0.0}} \
        -simstate NORMAL}
When I read this upf into xrun, the NET_V1P8_AVDD net/port is always stuck at 0, even if I force it in my testbench.
When:
is commented out, I can force NET_V1P8_AVDD to 1.
It seems UPF is forcing this node to 0.  Where and how to overcome it?
Thanks.
  • richardcromwell
    richardcromwell over 2 years ago
    It sounds like you are having trouble with UPF simulation and the NET_V1P8_AVDD net/port is always stuck at 0, even if you force it in your testbench. When you comment out the line connect_supply_net NET_V1P8_AVDD -ports { NET_V1P8_AVDD A/B/AVDD_pin }, you can force NET_V1P8_AVDD to 1.
    It’s possible that UPF is forcing this node to 0. To overcome this issue, you might try adding a power state for NET_V1P8_AVDD in your UPF file. Here is an example of how to add a power state:
    -state ON { -supply_expr {power == `{FULL_ON, 1.8} && ground == `{FULL_ON, 0.0}} \
    -simstate NORMAL}
    This will add a power state for PD_V1P8_AVDD.primary that sets NET_V1P8_AVDD to 1.8V and AGND to 0V.
