  2. Functional Verification
  3. simvision waveform window "placeholder for future object...
  • Subscribers 69
  • Views 3470
simvision waveform window "placeholder for future object creation"
wangyunxin
wangyunxin over 2 years ago
After loading the previously saved svwf file, there will be a horizontal line above the waveform appearing in the waveform window, and the reminder "placeholder for future object creation". Why is this and will it affect the simulation?
  • StephenH
    StephenH over 2 years ago +1
    This happens if the item you've tried to add to the waveform window does not exist in the waveform database. This may be because it's a dynamic object such as a class handle or a dynamic array, which hasn…
  • StephenH
    This happens if the item you've tried to add to the waveform window does not exist in the waveform database. This may be because it's a dynamic object such as a class handle or a dynamic array, which hasn't yet been created (if you're doing live simulation debug). If you're doing post-process debug then it's likely that you forgot to probe these signals when you ran the simulation.
  • swetha99
    swetha99 over 2 years ago in reply to StephenH
    Thank you for your reply!. It helped me Slight smile
