  2. Functional Verification
  3. $display() is executed immediately after simulation start...
  • Subscribers 69
  • Views 6555
$display() is executed immediately after simulation start although the condition in always statement (under which $display() resides) is not satisfied
alexek
alexek over 2 years ago
Hello!
I'm testing a small design of my own and I stumbled upon something I can't understand. When I hit 'run', I see immediately "Hello!" printed. Here is part of my testmodule:
initial begin
  init_done=0;
  <some other signals inits go here>
  <some delays goes here>
  init_done=1;
end
always @(negedge sig1) begin
    if (init_done) begin
       $display("Hello!");
       test_done <= 1;
    end
end
sig1 is raised for a couple of clocks when the DUT finishes its job. test_done is probed on each clock and when it is high, $finish() is issued.
So there are actually 2 questions here I can't answer:
1. Why always block executed without its condition being satisfied? I mean, if $display() is executed, it should mean that both negedge sig1 and init_done were satisfied?
2. Assuming always block was indeed executed, why test_done variable wasn't affected?
I'm aware of the "Events in Sequence Time" concept but I'd expect these to happen after "solid" init - starting from time 0, and not during init itself. Anyway, it does not describe the test_done being unaffected....
Would be glad for any help!
  • alexek
    It was my bad. I mixed up one code with another. I think this post can be safely deleted.
    Sorry for that.
    Alexei
