  2. Functional Verification
  3. How to pass environment variables exported from pre_session_script...
  • Subscribers 69
  • Views 5723
How to pass environment variables exported from pre_session_script to pre_group_script and run_script in vManager?
lscmarsh
lscmarsh over 2 years ago
My vsif goes like this:
session vm_example_sessions {
// Default sessions directory
top_dir : path/to/top_dir;
output_mode: terminal ;
// Try to use NC as DRM
drm: <text>nc</text>;
// Setup Simulation Env
pre_session_script : "path/to/vm_tb_setup.sh" ;
// Define test group and default simulation attributes for the group
group example_tests {
// compile once for test group
pre_group_script : "path/to/vm_compile_script.sh" ;
// run script to launch simulation
run_script : "path/to/vm_run_script.sh" ;
My pre_session_script:
#!/bin/sh
# Example of environment variable set
export RESULTS_HOME=$(pwd)
echo "RESULTS_HOME = $RESULTS_HOME"
My pre_group_script:
#!/bin/sh
echo "RESULTS_HOME check: $RESULTS_HOME"
# when executed:
# RESULTS_HOME check:
My run_script:
Is there a way to pass env variables from pre_session_script to the succeeding group and test scripts? I know I can source all the env variables before launching the VSIF but, I want to make VSIF source all of them instead.
  • StephenH
    StephenH over 1 year ago
    Every "*_script" attribute (run_script, pre_session_script etc) is run in isolation with no way to share environment between scripts. This is by design, because each script might be executing on a different host machine.
    There is an "sve_name" attribute which defines the path to a script that can be sourced before each other script gets executed. The file must be Bourne Shell (bash) compatible, so use "export var=value" format rather than "setenv var value".
