  2. Functional Verification
  3. Encountering issue (Unsupported OS) when using xrun -jg
  • Subscribers 69
  • Views 2841
JY202412054625
JY202412054625 over 1 year ago
I have recently migrated to a new cloud platform. I tried running running xrun -jg; however, I'm getting the following error message:
TOOL: xrun(64) 22.09-s005: Started on Dec 05, 2024 at 07:34:52 EST
xrun(64): 22.09-s005: (c) Copyright 1995-2023 Cadence Design Systems, Inc.
xrun: *W,ENVDEPRREN: Environment Variable (MSIRUN_HISTORY_OFF) is deprecated. Use (MSXRUN_HISTORY_OFF) instead.
xrun: *SE,JGUSOS: Jasper cannot run, "Rocky Linux 8.10 (Green Obsidian)" is an unsupported operating system. See "/apps/cadence/jasper/jasper_2024.06/doc/INSTALL.pdf" for a list of supported platforms.
xrun: *E,JGVER: The Jasper version could not be found. Verify the path set for Jasper.
TOOL: xrun(64) 22.09-s005: Exiting on Dec 05, 2024 at 07:34:52 EST (total: 00:00:00)
I have read that you can ignore unsupported OS. Any advise how?
  • walid6b
    walid6b over 1 year ago
    I too have faced similar problem. looking forward to some solution !!!
