  2. Functional Verification
  3. What is the condition for being able to use 'Send to Source...
  • Subscribers 67
  • Views 2476
What is the condition for being able to use 'Send to Source Browser' for a signal to work when viewing wave using simvision?
flyxtop
flyxtop over 1 year ago
Sometimes I open old simulatino result and try to follow how a signal has changed and I use 'Send to source Browser' for a signal.
But in some cases, simvision gives me error message and cannot open the relavant source file.
What is the exact condition for being able to connect to Source Browser in this situation? Does the xcelium.d director matter? (it seems it doesn't).
Thank you.
  • Doug Koslow
    Doug Koslow over 1 year ago
    Indeed, the xcelium.d is required to view the source code in SimVision. The waveform database contains a link to it, but if it cannot be opened for some reason, you will get an error message. If you have trouble loading the source, I suggest filing a support ticket for that on https://support.cadence.com/ and an AE can follow-up with you on it. Thanks.
    - Doug
