  2. Functional Verification
  3. *E,CUVUNF - Hierarchical name component lookup failed
  • Subscribers 67
  • Views 7231
dasheksh
dasheksh over 1 year ago
I have a for generate loop(named for block) - which instantiates modules 2 times, something like this
generate
for() begin : acc
//module instance
//I have to make a connection to make which is coming as an out of inst0 to inst1
end
endgenerate
//so I was trying to connect like this
//assign acc[0].inst.a = var[0];
//assign acc[1].inst.a = out[0]; // This comes as an output from acc[0].insta.out
But I come across the above mentioned error - If anyone could answer could be helpful.
Thanks in Advance
  • tpylant
    tpylant over 1 year ago
    I'm unsure what you're trying to do with the assigns. However, this code does work without error:
    module inst;
      logic a;
    endmodule
    module test;
    generate
      genvar i;
      for(i=0; i<2; i++) begin : acc
        inst inst ();
      end
    endgenerate
    assign acc[0].inst.a = acc[1].inst.a;
    endmodule
    Tim
  • dasheksh
    dasheksh over 1 year ago in reply to tpylant
    Thanks for the reply tpylant
    what if we have to access a port list
    module inst(a,b);
    input logic a;
    output logic b;
    endmodule
  • tpylant
    tpylant over 1 year ago in reply to dasheksh
    Did you try it? I didn't have a problem.
    module inst(input a, output b);
    endmodule
    module test;
    wire [1:0] in, out;
    generate
    genvar i;
        inst inst (in[i], out[i]);
      end
    endgenerate
    assign acc[0].inst.b = acc[1].inst.a;
    assign acc[1].inst.b = acc[0].inst.a;
    endmodule
    Tim
  • dasheksh
    Hi Tim,
    I see, Somehow I see a problem at my end when I try to access variable inside port list.
    Let me deep dive more. As of now I used a workaround to move forward.
    -Shek
