  2. Functional Verification
  3. waveform.wsf syntax manual
  • Subscribers 67
  • Views 6101
HN202503109055
HN202503109055 over 1 year ago
Is there any manual for editting the waveform.wsf file, that is created when saving user state in Verisium Debug?
Up till now, I made some customizations, and when I saved, I saw how it is written, and I editted it, but now I'm trying to add value highlighting, but it does not save anything in the wsf file.
Is there any LRM that defines which commands can be used?
  • Doug Koslow
    Doug Koslow over 1 year ago
    The waveform commands saved in the .wsf file are documented in the "Verisium Debugging for Xcelium Users" manual, which can be found here.
    However, that document may not be completely up-to-date with the latest command support. I suggest making sure you are running our latest release, Verisium Debug 25.01-a071, and using that to save the state of the waveforms. Any customizations you made should be saved. If not, please file a support ticket about it.
    Thanks.
    - Doug
