  2. Functional Verification
  3. Pass variables to tcl script in Xcelium
  • Subscribers 67
  • Views 8064
JF202503209845
JF202503209845 over 1 year ago
I'm trying to pass a Variable through a command line input in the environment, so that my tcl script can take this for its startup initialization.
xrun ... -command_that_sets_sets_a_variable -input "start_script_that_likes_to_read_a_variable.tcl" ...
The idea is that my tcl script loads different configs for SimVision depending on a string I input in the command line. That way I can simply swap out a word in my command line and Xcelium loads (for example) waveforms in a way I want/starts or not/sets breakpoints/whatever. I've tried a few options, but I either didn't understand the documentation or I've searched on the wrong end.
Kind regards
Jan
  • StephenH
    StephenH over 1 year ago
    Hi Jan.
    You can pass Tcl commands directly by starting the argument to -input with an "@" symbol:
    xrun -input "@set my_var 123" -input my_script_that_reads_my_var.tcl
    Hope this helps.
  • JF202503209845
    JF202503209845 over 1 year ago in reply to StephenH
    Hi Stephen,
    Solved my Problem, thank you.
    Kind regards,
    Jan
