  2. Functional Verification
  3. I observe following error when running xrun -sv
  • Replies 9
  • Subscribers 69
  • Views 10503
Tarique mohd
Tarique mohd over 1 year ago
Design hierarchy summary:
Instances Unique
Modules: 2 2
Verilog packages: 0 1
Registers: 15 15
Scalar wires: 12 -
Always blocks: 2 2
Initial blocks: 4 4
Pseudo assignments: 4 -
Simulation timescale: 100ps
Writing initial simulation snapshot: worklib.tb_light_fsm:sv
Loading snapshot worklib.tb_light_fsm:sv .................... Done
xcelium> source /eda/cadence/2023-24/RHELx86/XCELIUM_23.03.007/tools/xcelium/files/xmsimrc
xcelium> run
xmsim: *F,INTERR: INTERNAL EXCEPTION
Observed simulation time : 0 FS + 0
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
TOOL: xmsim(64) 23.03-s007
HOSTNAME: icdtsmc28nm.ewi.tudelft.nl
OPERATING SYSTEM: Linux 4.18.0-553.22.1.el8_10.x86_64 #1 SMP Wed Sep 25 09:20:43 UTC 2024 x86_64
MESSAGE: T(0): sv_seghandler - trapno -1 addr(0x4aa4ccc)
Stream rts_xfer
csi-xmsim - CSI: Cadence Support Investigation, sending details to /users/mtarique/28nm/T28HPCP/SV_code/xmsim_4106232.err
csi-xmsim - CSI: investigation complete, send /users/mtarique/28nm/T28HPCP/SV_code/xmsim_4106232.err to Cadence Support
  • tpylant
    tpylant over 1 year ago +1
    Did you look at the /users/mtarique/28nm/T28HPCP/SV_code/xmsim_4106232.err file? Tim
  • tpylant
    Tim
  • Tarique mohd
    Tarique mohd over 1 year ago in reply to tpylant
    Yes I saw message which direct to Cadence support, not sure about  the root cause, the message is as follows
    Stream rts_xfer
    csi-xmsim - CSI: Cadence Support Investigation, recording details
    External Code in function: <unavailable> offset -65516
    External Code in function: <unavailable> offset -65536
    External Code in function: <unavailable> offset -65535
    Simulator Snap Shot: root (SSS_ROOT) in snapshot worklib.tb_light_fsm:sv (SSS)
    Intermediate File: root (IF_ROOT) in snapshot worklib.tb_light_fsm:sv (SSS)
    Simulator Snap Shot: dynlib (SSS_DYNLIB) in snapshot worklib.tb_light_fsm:sv (SSS)
    Intermediate File: data block (IF_BLK) in snapshot worklib.tb_light_fsm:sv (SSS)
    Code Item: root (COD_ROOT)
    External Code in function: <unavailable> offset -65500
    External Code in function: <unavailable> offset -65518
    User Code in function: <unavailable> offset 42600727
    csi-xmsim - CSI: investigation complete took 0.010 secs, send this file to Cadence Support
  • Tarique mohd
    Yes I saw, but  not sure about the issue , is it tool issue or something else the message reflects send this file to cadence  support
    Stream rts_xfer
  • Tarique mohd
    Stream rts_xfer
  • Tarique mohd
    The content of file is
    csi-xmsim - CSI: Command line:
    xmsim
    -f /users/mtarique/28nm/T28HPCP/SV_code/xcelium.d/run.lnx8664.23.03.d/icdtsmc28nm.ewi.tudelft.nl_4106232/xmsim.args
    -MESSAGES
    +EMGRLOG xrun.log
    -XLSTIME 1743519516
    -XLKEEP
    -XLMODE ./xcelium.d/run.lnx8664.23.03.d
    -RUNMODE
    -CDSLIB ./xcelium.d/run.lnx8664.23.03.d/cds.lib
    -HDLVAR ./xcelium.d/run.lnx8664.23.03.d/hdl.var
    -XLNAME xrun
    -XLVERSION TOOL: xrun(64) 23.03-s007
    -XLNAME ./xcelium.d/run.lnx8664.23.03.d/icdtsmc28nm.ewi.tudelft.nl_4106232
    -CHECK_VERSION TOOL: xrun(64) 23.03-s007
    -LOG_FD 4
    -LOG_FD_NAME xrun.log
    -cmdnopsim
    -runlock /users/mtarique/28nm/T28HPCP/SV_code/xcelium.d/run.lnx8664.23.03.d/.xmlib.lock
    -runscratch /users/mtarique/28nm/T28HPCP/SV_code/xcelium.d/run.lnx8664.23.03.d/icdtsmc28nm.ewi.tudelft.nl_4106232
    csi-xmsim - CSI: *F,INTERR: INTERNAL EXCEPTION
    Stream rts_xfer
  • tpylant
    That's going to be difficult to diagnose from a Forum discussion. I suggest you click the Support button at the top of the screen and submit a ticket to get someone who can work directly with you on this problem.
    Tim
  • tpylant
    tpylant over 1 year ago in reply to Tarique mohd
    It's a time 0 simulation crash. You would hope there would be some clues to what caused it but it is pointing to external code in an unavailable function name.
    You can try running with a different version but I'm just shooting in the dark.
    Tim
  • AM20250527826
    AM20250527826 over 1 year ago
    Hi Tarique,
    I am having the same problem, and I was wondering if you have found the solution?
    Ali Moaz
  • shykat
    shykat over 1 year ago in reply to AM20250527826
    I see the same issue, looks like it is related to XLM version and RHEL8 Linux versions. Better to deal with an AE directly.
