  2. Functional Verification
  3. SimVision: how to find all signals in the database matching...
  • Subscribers 68
  • Views 6972
SimVision: how to find all signals in the database matching a specific pattern?
ES20241003727
ES20241003727 over 1 year ago
Let's imagine I have a signal in my waveform database like test.top.channel_0.subChannel_A.mySignal.
My design has many identical channels and each channel has many identical sub-channels, so the following signals also exist in the waveform database:
test.top.channel_0.subChannel_B.mySignal
test.top.channel_1.subChannel_A.mySignal
test.top.channel_1.subChannel_B.mySignal
I would like to add every instance of mySignal that exists in the design to the waveform. Ideally, I would like to do this by just specifying a wildcard/glob pattern, so I can find and add all signals in the design/database of the form:
test.top.channel_*.subChannel_*.mySignal
How can I do this with SimVision?
Initially I thought the "Design Search" window could find all the signals for me, but it seems like there is no option in Design Search to match against the entire hierarchical signal/path name - you can match against just the last part of the scope with the "Consider:" option set to "Scopes":
or just the signal/variable name with the "Consider:" option set to "Signals/Variables":
but not against the entire hierarchal path at once (the "All Design Elements" option for "Consider:" seems to match against each piece of the hierarchy instead of the entire hierarchy path as a whole).
My design might also have signals of the form test.top.someOtherBlock.mySignal that I do NOT want returned, so simply searching for all signals named "mySignal" regardless of hierarchy won't work - I really need to match against the full hierarchy path, with wildcards.
I tried looking at the SimVision TCL command reference to see if there was a way to search through the database/design browser using TCL, but I couldn't find anything useful.
Does anyone have any suggestions on ways to do this?
  • StephenH
    StephenH over 1 year ago
    You could probably achieve this using SimVIsion's Tcl scripting, to navigate the design and procedurally add the signals to the waveform. If you wrote such a script, it could be attached to a SimVision GUI button.
    However, SimVision is a legacy tool that is not actively developed and I would strongly recommend moving to Verisium Debug, which has far more powerful capabilities including a global search which would easily accomplish what you're asking for. Speak to your local Cadence AE if you want more information on how to use Verisium Debug, or take a look at the collateral under https://support.cadence.com/verisiumdebug
