  2. Functional Verification
  3. Simple Assertion for Counter
  • Subscribers 68
  • Views 4344
TM202505254140
TM202505254140 over 1 year ago
Hi all,
Question_1 : Assertion requirement :
When Enable is HIGH, counter should be increment to previous clock cycle value, when Enable is LOW, counter should keep same value as previous cycle.
Below is my understanding. May I know is this satisfying the requirement or require changes?
property p1;
@(posedge clk) Enable |=> (count == $past(count+1));
endproperty
Question_2 : also, do we require one more property for else condition. Like
property p2;
@(posedge clk) (!Enable) |=> (count == $past(count));
endproperty
Is only one property (p1) is sufficient for above requirement.
Kindly suggest
  • tba786
    tba786 over 1 year ago
    I would say both. Try them and share the result
