  2. Functional Verification
  3. Functional Coverage at SOC or Sub System Level
  • Subscribers 67
  • Views 4882
TM202505254140
TM202505254140 over 1 year ago
Hi All,
At subsystem or SOC verification level,
let’s say there are three IPs integrated : IP1, IP2 and IP3.
Individually from block level verification, all IPs functional coverage is achieved 100%.
IP1 FC 100%
IP2 FC 100%
IP3 FC 100%
But at the subsystem level, when I run some tests or regression, functional coverage is still 60 to 70%. What would be the understanding here?
case_1 : We need to still add tests to make 100% coverage even at SOC level
case_2 : Getting coverage (code or FC) 70% at SOC level is still acceptable, no need to wait for 100% coverage since individually all IPs are already verified.
So, Now I need to sign-off. Can I proceed with just 70% coverage at SOC level,
requesting everyone to share thoughts here.
I am interesting in measuring sign off factors at SOC or sub system level.
Kindly provide your inputs.
  • StephenH
    StephenH over 1 year ago
    This is quite an academic question. Coverage is simply a metric to tell you what you have not exercised in your verification process. I think most engineers would not aim to re-verify all the internals of an IP further up the integration levels, thus trying to achieve 100% coverage on the IP makes no sense and would add significantly to the cost of verifying the subsystem or SoC. Focus on verifying the integration of the IP into the subsystem - this tends to be more about exercising use cases and ensuring that the subsystem behaves correctly with the IP in it.
