  2. Functional Verification
  3. I'm using RHEL 8.10, and XCELIUM MAIN version 23.09_013...
  • Subscribers 67
  • Views 1547
I'm using RHEL 8.10, and XCELIUM MAIN version 23.09_013 isn't working properly.
CH20260126886
CH20260126886 9 months ago
I'm using RHEL 8.10, and XCELIUM MAIN version 23.09_013 isn't working properly. Is there a problem with the OS? The log is as follows.
csi-xmsim - CSI: Command line:
xmsim
-f ./test_sim/xcelium.d/run.lnx8664.23.09.d/smidc203_3677635/xmsim.args
-MESSAGES
+EMGRLOG xrun.log
-XLSTIME 1769475002
-XLKEEP
-XLMODE ./xcelium.d/run.lnx8664.23.09.d
-RUNMODE
-CDSLIB ./xcelium.d/run.lnx8664.23.09.d/cds.lib
-HDLVAR ./xcelium.d/run.lnx8664.23.09.d/hdl.var
-XLNAME xrun
-XLVERSION TOOL: xrun(64) 23.09-s013
-XLNAME ./xcelium.d/run.lnx8664.23.09.d/smidc203_3677635
-CHECK_VERSION TOOL: xrun(64) 23.09-s013
-LOG_FD 4
-LOG_FD_NAME xrun.log
-cmdnopsim
-runlock ./test_sim/xcelium.d/run.lnx8664.23.09.d/.xmlib.lock
-runscratch ./test_sim/xcelium.d/run.lnx8664.23.09.d/smidc203_3677635
csi-xmsim - CSI: *F,INTERR: INTERNAL EXCEPTION
Observed simulation time : 0 FS + 0
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
TOOL: xmsim(64) 23.09-s013 (CL: 680443 )
HOSTNAME: smidc203
OPERATING SYSTEM: Linux 4.18.0-553.el8_10.x86_64 #1 SMP Fri May 10 15:19:13 EDT 2024 x86_64
MESSAGE: T(0): sv_seghandler - trapno -1 addr(0x50153ec)
Stream rts_xfer
csi-xmsim - CSI: Cadence Support Investigation, recording details
External Code in function: <unavailable> offset -65519
External Code in function: <unavailable> offset -65536
Simulator Snap Shot: gd (SSS_GD) in snapshot worklib.tb:v (SSS)
Intermediate File: array of pointers (IF_PTRBLK) in snapshot worklib.tb:v (SSS)
Error: Error processing stack frame(8) - skipping rest of frame!
External Code in function: <unavailable> offset -65535
Simulator Snap Shot: root (SSS_ROOT) in snapshot worklib.tb:v (SSS)
Intermediate File: root (IF_ROOT) in snapshot worklib.tb:v (SSS)
Intermediate File: data block (IF_BLK) in snapshot worklib.tb:v (SSS)
Simulator Snap Shot: dynlib (SSS_DYNLIB) in snapshot worklib.tb:v (SSS)
External Code in function: <unavailable> offset -65531
csi-xmsim - CSI: investigation complete took 0.019 secs, send this file to Cadence Support
