  2. Functional Verification
  3. Which Assertion Language to Use?
  • Subscribers 66
  • Views 14725
archive over 20 years ago
        There are two standard assertion langages PSL (Property Specification Language) and SVA (SystemVerilog Assertions). They are both IEEE standards and they are both supported by most EDA vendors.
Which one should I use?
SVA is part of the SystemVerilog language so if your design is in SystemVerilog, SVA is a good choice.
PSL is a property language designed to work with Verilog, VHDL, SystemVerilog and SystemC so if your design is VHDL or a mix of languages, PSL is a good choice.
Both language offer similar capabilities but there are a couple of differences:
  • SVA assertions always have a clock. In PSL you don't have to evaluate an assertion on a clock edge.
  • PSL assertions are entered as comments in the code or in a separate file whereas SVA assertions are part of the RTL language.
    Anders Nordstrom
    Architect
    Incisive Formal
    Cadence Design Systems.
Originally posted in cdnusers.org by andersn
