  2. Functional Verification
  3. verification of connectivity at top-level
  • Subscribers 66
  • Views 14996
archive over 20 years ago
How do you verify the connectivity at the top-level? How to make sure a user has not messed up a[m:n] with a[n:m]? Do you generally use simulation and toggle coverage to verify this or formal?
Your insight will be appreciated.
Sibil
Originally posted in cdnusers.org by Sibil
    Hi Sibil,
    Let's take an example:
    - Assume the top level module is called top
    - Assume top instantiates blocks 'A' and 'B'
    - Assume blocks 'A' and 'B' have inputs data_in[63:0] and data_out[63:0]
    - Assume at the top level data_out from block A should be connected to data_in of block B
    You could write an assertion that checks that "top.data_out[63:0] is equal to top.data_in[63:0]". If you feed this assertion to IFV it will either be trivially true of trivially false; runtime should be very quick (should be approximately equal to the time it takes to read the design into the tool).
    Amir
    Originally posted in cdnusers.org by amirl
