  2. Functional Verification
  3. modeling a constraint for a signal that is only high once...
  • Subscribers 66
  • Views 16631
modeling a constraint for a signal that is only high once (ever)
archive over 19 years ago
How can I model a constraint for a signal that is supposed to be high only once
in PSL?
Originally posted in cdnusers.org by ssa
    What about:
    // psl assume_single_high_pulse: assume {!a[*];[a];!a[*]};
    Originally posted in cdnusers.org by jb
    Thanks jb.
    Tried it but it seems not to work.
    I can get two times a - even consecutively with this constraint applied.
    Might be due to to the last term in the sequence !a[*] - where !a[*0] (meta code) is a legal match.
    Any other suggestions?
    You need another constraint:
    // psl assume_no_second_pulse : assume never {a; !a[*]; a};
    Originally posted in cdnusers.org by foster
    The following single constrtaint seems to work:
    // psl no2a: assume never { a[->2] };
    It doesn't say that 'a' has to occur once, it only says that it can't occur twice.
    Originally posted in cdnusers.org by TAM
    Thanks guys - both never version work great.
    I found another alternative: never {a[=2]};
