  2. Functional Verification
  3. keeping rst asserted n clocks into the proof
  • Subscribers 66
  • Views 15444
archive over 19 years ago
Anyone know how to keep rst_n asserted 16  clocks iinto the proof and then deassert forever  with SVA?  I can do this easily in PSL by using assume and omitting always as in the following PSL:
// Assert rst_n for 16 clocks, then deassert for one clock. Note absense of "always"
// It fires once only during the clock 1
// psl assume_rst_n_low_16: assume {!rst_n[*16];rst_n} @ (posedge clk);
// This property ensures rst_n stays high once it goes high from previous property.
// psl assume_rst_n_high_rest_of_time: assume always {rst_n}|=> {rst_n};
I am trying avoid auxilliary code with SVA but I have not come up with a clean way to avoid the aux code.  In fact the aux code I have requires an undriven signal to code a trigger for clock 1 to implement the equivalent of PSL assume_rst_n_low_16 property above.
JB
Originally posted in cdnusers.org by jb
    I don't want to get too sophistical, but I look at SVA as just another kind of auxiliary verification logic, so I don't understand the motivation for the question. SVA as well as auxiliary logic should be encapsulated into ifdef pragmas anyway to avoid downstream problems in the flow.
    The reason I am saying this is because I don't see a way to write this without aux code in SVA (until IFV supports assertions inside procedural initial blocks, which probably no formal tool supports).
    Originally posted in cdnusers.org by foster
    Foster,
    Thanks for confirming you see no other way than using axilliary code to implement this in SVA.  I agree that all this would be encapsulated within `ifdefs to eliminate the code from issues with downstream flow.
    I was simply trying to see if there was a way to implement the functionality in SVA that was possible in PSL.  I have dealt with requests before to keep rst_n asserted into a proof with PSL up till now.  As there are more and more SVA users I wanted to have an implementation in SVA handy for these users.
    jb
