  2. Functional Verification
  3. forall and endpoint/ended
  • Subscribers 66
  • Views 737
archive over 19 years ago
The module below has 2 assumption examples (one using endpoint and one using ended()).  In each of them, I am trying to only allow responses to addresses that have already had requests made to them.
Before forall support, a stable, undriven signal was used for the index in properties like the ones below.  Now, with forall support, I'm trying to come up with a more portable and complete solution.  However, both properties fail in the compilation.  Can someone expalain the "undeclared identifier"s problem?  There only seems to be a "undeclared" problem inside of ended or endpoint.
Thanks!
<br>module test<br>#(<br>parameter<br>MEM_D=8,<br>ADDR_W=3<br>)<br>(<br>input clk,<br>input rq_valid,rs_valid,<br>input [ADDR_W-1:0] rq_addr,rs_addr<br><br>);<br><br>//psl endpoint rq_to_rs(const i)=<br>// {rq_valid & rq_addr==i;~(rs_valid & rs_addr==i)[*];rs_valid & rs_addr==i}<br>//;<br><br>//psl assume_good_rs0: assume<br>// forall i in {0:MEM_D-1}: always(<br>// {rs_valid & rs_addr==i} |-> <br>// {rq_to_rs(i)} <br>//)@(posedge clk);<br><br>//psl assume_good_rs1: assume<br>// forall i in {0:MEM_D-1}: always(<br>// {rs_valid & rs_addr==i} |-> <br>// {ended({rq_valid & rq_addr==i;</font></font><font color="#0000ff"><font face="Courier New">~(rs_valid & rs_addr==i)</font></font><font color="#0000ff"><font face="Courier New">[*];rs_valid & rs_addr==i})} <br>//)@(posedge clk);<br><br><br>endmodule
Error with module above:
$ ifv test.v -s
ifv: 05.83-s001: (c) Copyright 1995-2007 Cadence Design Systems, Inc.
file: test.v
// {ended({rq_valid & rq_addr==i;~(rs_valid & rs_addr==i)[*];rs_valid & rs_addr==i})}
ncvlog: *E,UNDIDN (test.v,27|31): 'i': undeclared identifier [12.5(IEEE)].
ncvlog: *E,UNDIDN (test.v,27|55): 'i': undeclared identifier [12.5(IEEE)].
ncvlog: *E,UNDIDN (test.v,27|81): 'i': undeclared identifier [12.5(IEEE)].
        module worklib.test:v
                errors: 3, warnings: 2
ncvlog: *F,NOTOPL: no top-level unit found, must have recursive instances.
ncverilog: *E,VLGERR: An error occurred during parsing.  Review the log file for errors with the code *E and fix those identified problems to proceed.  Exiting with code (status 2).
ifv: *F,EXEERR: Errors encountered, exiting FormalVerifier. Check formalverifier.log for details.
Error if assume_good_rs1 is commented out.
$ ifv test.v -s
file: test.v
// {rq_to_rs(i)}
ncvlog: *E,UNDIDN (test.v,21|0): 'assume_good_rs0_forgen_0__i': undeclared identifier [12.5(IEEE)].
                errors: 1, warnings: 1
Originally posted in cdnusers.org by weberrm
