  2. Functional Verification
  3. How to debug HAL check error messages?
  • Subscribers 66
  • Views 18335
archive over 19 years ago
I am trying to verify a VHDL-verilog mixed design with IFV 5.83-s003.  When I am trying to compile all the modules and entities, I am getting several error messages of the following kind,
halcheck *E, STDPKG (filename): The IEEE package 'std_logic_arith' should not be used.
USE IEEE.std_logic_arith.ALL;
halcheck: *E, RTLNOP (filename): Primitive instances are not expected in an RTL design.
mu1udp #0 MUX2_UDP0 (Y,S,A,B);
I have identified that there is one verilog file which when added to the .f file creates this problem. Otherwise, formalbuild goes through well. However, as soon as I add this file, errors are flooded regarding the other VHDL files in the design. I cannot change the design and rectify these problems. I have to verify the design the way it is. What is the solution to this? Is there any way to disable HAL checks or change the severity from 'Error' to 'Warning' so that the formalbuild goes through?
Thanks in anticipation.
Originally posted in cdnusers.org by bijitm
    Go ahead and contact a Cadence AE regarding this issue.  It will be your best course of action at this time.
    JB
    Originally posted in cdnusers.org by jb
    You can turn off these HAL checks by switching these off in a local HAL definitions file and passing this local definitions file to 'ifv'. The local definitions file will be as follows:
    local.def:
    include default
    params STDPKG {off}
    params RTNOP {off}
    % ifv [other_options] +haldefines+./local.def
    Hope this helps!
    Originally posted in cdnusers.org by kanwars
    local.def:
    include default
    params STDPKG {off}
    params RTLNOP {off}
    Hope this helps!
