  2. Functional Verification
  3. ifv: initialisation with init -load
  • Subscribers 66
  • Views 2220
archive over 19 years ago
I am trying to initialise my design with loading the waveforms from normal simulation because ifv is having difficulties with normal procedur (apply reset and run a few cycles)
I tried to load the waves but I don't have the syntax exactly right. Can anybody help?
My traces are in :
../nccoex/rundir_otb_ddrii/traces/
containing traces.dsn and traces.trn
When I open the traces with simvison the database is called traces::
I tried:
=>FormalVerifier> init -load -sst2 ../nccoex/rundir_otb_ddrii/traces -time 150ns
'1493' Signals not found in database, retaining old values for these signals.
formalverifier: Initial value of state variables loaded from SST2 database at time "1.5e-7s".
=>FormalVerifier> init -load -sst2 traces -root ../nccoex/rundir_otb_ddrii/traces -time 150ns
formalverifier: *E,SSDBER: Could not load database traces : No such file or directory.
=>FormalVerifier> init -load -sst2 ../nccoex/rundir_otb_ddrii/traces -root traces -time 150ns
formalverifier: *E,SSDBSC: Can not find top module "traces" in database ../nccoex/rundir_otb_ddrii/traces.
=>FormalVerifier> init -load -sst2 ../nccoex/rundir_otb_ddrii/traces -root traces::ip_pnx8542_2032lib.ip_pnx8542_2032_tb(testbench) -time 150ns
formalverifier: *E,SSDBSC: Can not find top module "traces::ip_pnx8542_2032lib.ip_pnx8542_2032_tb(testbench)" in database ../nccoex/rundir_otb_ddrii/traces.
If I do init -show the still all registers are 1'bx
Frank
Originally posted in cdnusers.org by frank.vaneerdewegh
    Hi Frank,
    you need to specify the root path to the toplevel, starting with ":" for the toplevel, e.g. if you have the following:
    Sim hierarchy: ip_pnx8542_2032_tb:dut
    IFV hierarchy: dut
    init -load -sst2 ../nccoex/rundir_otb_ddrii/traces -root [b]:dut[/b] -time 150ns
    What kind of issues are you facing with the Tcl initialization?
    Joerg.
    Originally posted in cdnusers.org by foster
    Sorry for the HTML formatting, here it is correct:
    init -load -sst2 ../nccoex/rundir_otb_ddrii/traces -root :dut -time 150ns
    Hi Foster,
    Thanks for your quick reply, the issue is resolved now.
    The issue I had was that when I did a reset and then invoked the logic simulator a few cycles the simulator hang itself. This is most likely caused because I have read in some code which can not be synthesized.
    By reading in the waves from the normal simulation run I am able to initialize the design and prevent the hang up.
    Thanks again for your help
    Frank
