  2. Functional Verification
  3. Auxiliary code:Tick event not synthesiseable
  • Subscribers 66
  • Views 1655
archive over 19 years ago
why is a tick event without defining rising or falling edge not allowed in auxiliary code (" elsif clock'event then ..."), as it is a legal construct for use in a testbench and doesn't have to be synthesisable?
Thanks.
Originally posted in cdnusers.org by Thomas666
    Hi Thomas666,
    Does your question have to do with Conformal? If so, Conformal only reads synthesizable code. You should not be reading in your testbench. If it doesn't have to do with Conformal could you please specify what tool you have an issue with?
    Originally posted in cdnusers.org by claym
    Hi Claym,
    i am doing FV with IFV and the VHDL compilation is done using ncvhdl.
    Hi Thomas666,
    tick event without defining rising or falling edge is not synthesizable and therefore it is not going to work in IFV. What are you trying to model which requires tick event without defining rising/falling edge? Please provide more information so we can address it properly.
    Amir
    Originally posted in cdnusers.org by Sibil
