  2. Functional Verification
  3. IFV Regresssion
  • Replies 8
  • Subscribers 66
  • Views 18529
IFV Regresssion
archive over 19 years ago
Hello ,
   I am using IFV to check the hook up in a large SOC .
   We have around 2000 assertions .  That means the total
   assertion run takes so much time ( I am using a single IFV gui ) .
    Is there any workaround ? like simulations can we have batch mode
    jobs for these assertion runs . We are using a farm of servers .
Regards
Jentil Jose
Originally posted in cdnusers.org by jent
    Hi Jentil Jose.
    If you have more than one licence available, you could use a TCL script to control the proof, such that only N properties are proven in each run. Then run IFV on multiple machines, with a parameter to the TCL file which selects the set of properties to prove on that machine.
    If your assertions have a good naming scheme it would be easy to use the "assertion -delete" command to select the properties by IP block name for example.
    Of course you'd need to merge the results after all the runs complete, but that would be fairly easy with a bit of perl or awk scripting.
    Originally posted in cdnusers.org by stephenh
    Hi Steve H .
    Thanks , This sounds helpful for me . However , is there a way to run different IFV sessions
    in a single run directory ? I suppose a lock file is generated to avoid
    multiple sessions in a single run directory .
    Regards
    Jentil Jose
    Good point!
    I would imagine that you could use the +nclibdirname+
    option to IFV, and run each session in a new directory.
    For example:
    Project dir:
    /projects/mysoc/ifv
    Run 1st session in:
    /projects/mysoc/ifv/run1
    Using command:
    ifv -f ../mysoc.ifv +nclibdirname+/projects/mysoc/ifv/INCA_libs
    Then each subsequent session in run2, run3... using the exact same +nclibdirname option.
    You may also need a +cdslib option to specify a common cds.lib file if you're using VHDL.
    I haven't tried this with IFV, but it works fine for IUS.
    If it works, can you let us know on the forum?
    Jentil,
    Which version of IFV are you using?  IFV 6.11s001 provided a significant performance boost over previous versions out of the box.  Please ensure you are using s001 or newer version.
    Another thing to try is to run the proof without the GUI.  You can always bring up the gui at the end of the proof by running the tcl command "simvision" at the formalverifier prompt.  See if the runtimes are significantly improved.
    Try this before creating parallel runs. This alone may avoid you having to break up your runs.
    Jose
    Originally posted in cdnusers.org by jb
    Hi Jose ,
    I used IFV 6.11s001 in non GUI , this solves my problem .
    Thanks for the suggestion.
    Regards
    Jentil
    Jentil,
    Do you mind sharing what provided the performance boost with the community? Was it upgrading to 6.11s001 or runing in non-GUI mode or a combination of both?
    Jose
    Jose ,
    The speed improvement was mainly because of the new version 6.11s001 .
    please see the statitics -
    Previous Versions ( in GUI ) -- 5 -10 minutes per assertion
    6.11s001 ( GUI ) --- 20 seconds per assertion !
    6.11 s001 ( non GUI ) -- 14 seconds per assertion !
    In all the above we used same set of assertions .
    Jose ,
    Regards
    Jentil
