  2. Functional Verification
  3. IFV, prove one assertion
  • Subscribers 66
  • Views 15626
archive over 18 years ago
Sometimes I want to prove just one assertion or cover.  I run the steps below filling in the last assertion step with the assertion or cover requested.
assertion -delete -cover
assertion -delete -specification
assertion -add assertion [-specification | -cover]
prove
Any suggestions on how to automate this?  Ideally, I would like to right-click the assertion and click prove from menu.
Thanks!
Originally posted in cdnusers.org by weberrm
    I would write a TCL procedure that takes the assertion name as the parameter ( or the type as you asked for):
    proc only_prove { prop_name } {
    assertion -add $prop_name
    prove
    then you can just do:
    only_prove tb.prop1
    etc
    You can also use this idea to make a new GUI toolbar button.
    Take a look at the following article to see how it's done:
    http://www.cdnusers.org/Forums/tabid/52/forumid/64/postid/3933/view/topic/Default.aspx
    Originally posted in cdnusers.org by stephenh
    Steve,
    I implemented the button as you suggested. This works well in conjunction with a custom button that runs the following tcl code for this button:
    only_prove %s
    Make sure you click the box for "selection sensitive to selection" and select from the drop down to make this a FormalVerifier script command.
    Consider not delelting all assertions in the proc as you will not be able to get results at the end of the run via the assertion -show command. In otherwords, put the commands:
    ass -del -all
    in the base tcl script and have the proc add the specified assertion and prove. You will then accumulate results in the gui and ass -show tcl command.
    JB
    Originally posted in cdnusers.org by jb
