  2. Functional Verification
  3. Complete Simulation Run when Assertion fails
  • Subscribers 66
  • Views 23761
archive over 18 years ago
hi Cdnusers,
      I am writing SV assertions and using  IUS 5.8 simulator, While running the SV assertions if an assertion fails the simulation is getting Stopped.
     I wrote 10 assertions and  simulator run is getting stopped if a 4th assertions failing on some Error injection but i want to check the allied assertion failures for the  6th and 7th assertion also.
     Please suggest me a way to continue Simulation run when assertion fails and get a list of all Assertion failures.
Originally posted in cdnusers.org by ramesh_pal_yadav
    Hi Ramesh,
    you need the following command:
    assert_stop_level never
    See also http://sourcelink.cadence.com/docs/files/Release_Info/Docs/ncvlog/ncvlog6.2/debugging.html#1028139
    Joerg.
    Originally posted in cdnusers.org by jmueller
    Hi Jeorg,
    Now i am working with IES 6.2 where i am usinf "irun" command for compilation,elaboration and simulation. Here i couldnt find any support for "assert_stop_level".I am getting an Error as
     irun: *E,BDOPT: Unknown option -assert_stop_level.
    Is there any other way that i can Make my Assertion Errors covert into Warnings to Enable Complete Simulation Run ??
    Thanks and regards,
    RP Yadav
    Hi RP Yadav,
    The assert_stop_level is a TCL command to ncsim. Though I've not tried it inside irun, I believe irun would accept some form of a runtime TCL/DO file similar to:
    ncsim top -input cmd.tcl
    That should work for you. Else there used to be a variable NCSIMARGS in hdl.var that you can set - but that's round about a way.
    HTH
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
