  2. Functional Verification
  3. Parameterized classes
  • Subscribers 66
  • Views 15488
archive over 20 years ago
I was wondering if/when parameterized classes were going to be supported?  I seem to be getting errors in 5.7-s1 of seemingly legal syntax according to the 3.1a System Verilog LRM section 11.23.
class class_test #(int W=5);
ncvlog: *E,NULLPP (test.v,3|21): empty/illegal list of parameters [12.1(IEEE-2001)].
The error seems to be referring to the 12.1 Modules section of the Verilog 2001 LRM.
SV 3.1a LRM excerpt:
11.23 Parameterized classes
It is often useful to define a generic class whose objects can be instantiated to have different array sizes or data
types. This avoids writing similar code for each size or type, and allows a single specification to be used for
objects that are fundamentally different, and (like a templated class in C++) not interchangeable.
The normal Verilog parameter mechanism is used to parameterize a class:
class vector #(int size = 1);
bit [size-1:0] a;
endclass
Instances of this class can then be instantiated like modules or interfaces:
vector #(10) vten; // object with vector of size 10
vector #(.size(2)) vtwo; // object with vector of size 2
typedef vector#(4) Vfour; // Class with vector of size 4
Originally posted in cdnusers.org by weberrm
    From what I've gathered, it doesn't sound like parameterized classes will available until IUS 5.9.  That's too bad...
