  2. Functional Verification
  3. serial transmission of structures
  • Subscribers 66
  • Views 15295
archive over 20 years ago
hi there
I am looking for a 'proper' way to serially send data on a line (my application is ISO7816 but it could be any serial p[rotocol modeling)
Data are defined by
typedef enum byte {direct = 8'h3b, inverse = 8'h3f} t_InitChar;
typedef struct packed {
  bit td;
  bit tc;
  bit tb;
  bit ta;
  bit [3:0] nr_hist;
} t_FormatChar;
Which define the 7816 ATR patter
  t_InitChar ts;
  t_FormatChar t0;
} t_atr;
I  can to send this patter by a s2p converter using the following
module p2s (in_array, out1, clk, reset, en);
parameter LE = 8;
   input clk, reset, en;
   input [LE-1:0] in_array;
   output      out1;
   reg [LE:0]   par;
   reg         out1;
   always @(posedge clk) begin
      if (reset)
          par
      else if (en)
          par
      else
          {out1,par}
   end // always @ (posedge clk)
endmodule // p2s
and compose a pre-filled array by the structure members: still, I feel this is not the proper 'SystemVerolog'  way
Srry for this newbie question by a Verilog user which is moving into System verilog :-)
thanks
Originally posted in cdnusers.org by marco.stanzani
    Hello Marco,
    Since you defined your t_FormatChar type as a packed structure, you can treat it as a vector or access the individual fields. So your p2s module should be fine.  If you don't need to synthesize the p2s module you can use a task to do the parallel to serial transmission.  I have attached an example to this response in case you are interested.
    I hope that helps!
    Kathleen
    Originally posted in cdnusers.org by kameade
    • p2s.txt
